Home > In Car Electronics (L322) > Sat Nav issues |
CongoBoy Member Since: 11 Sep 2020 Location: Wiltshire Posts: 126 |
GPS antenna.
29th Nov 2021 7:12pm |
Pogo Member Since: 28 Nov 2021 Location: Cheshire Posts: 34 |
Thanks for the reply. I've found a couple and I've watched a video for replacing it and I'm comfortable with that.
29th Nov 2021 7:42pm |
OK, I changed the antenna for a brand new Land Rover part.
5th Dec 2021 4:55pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35363 |
check battery condition if ok do a battery reset..
5th Dec 2021 5:08pm |
Thanks, I'll check the battery as suggested. I guess the battery could be on the way out as the radio station resets after each start, but I noticed today that it if I just turn the ignition on (without starting the car) the preset station comes on.
5th Dec 2021 5:34pm |
I have just checked my battery and got the following results -
6th Dec 2021 12:19pm |
your 4.2 is easy to start but the electronics are really voltage sensitive...
6th Dec 2021 12:25pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3237 |
Looks as if your battery is on its way out. Running it flat won't have helped. Try charging it and leaving it overnight disconnected to see what you get as a voltage reading. John
OK, but doesn't disconnecting the battery cause other issues?
6th Dec 2021 12:29pm |
Well re-setting the clock isn’t a big issue and you have to turn steering lock to lock with the engine running to re-set it but, apart from that, no issues .
6th Dec 2021 3:49pm |
OK, thanks John. I'll do that tomorrow and see how we go. I'm really good at setting the clock now
6th Dec 2021 4:07pm |
So I've removed my battery and charged it and it took the charge well and passed the charger's checks.
7th Dec 2021 7:47pm |
To do a battery reset you disconnect it and hold the ends of the battery leads together positive to negative for a few seconds. Has the effect of discharging the ECUs so that when you reconnect the battery it is starting from afresh, as it were
7th Dec 2021 8:13pm |
Thanks John
7th Dec 2021 8:59pm |
