![]() | Home > Maintenance & Mods (L322) > What to do if your DPF is blocked... |
RRDunc Member Since: 26 Feb 2020 Location: Leicestershire/Warwickshire border Posts: 520 ![]() ![]() ![]() |
That is probably the most helpful explanation of DPF regens that I've seen.
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1271 ![]() ![]() ![]() |
Ah ha. Very interesting mate and yes I was on about the yellow warning light. I have got an IID tool but I tried to get the DRL's working once and loads of other things stopped working so I don't use it very often. |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4323 ![]() ![]() ![]() |
I think you mean "don't worry too much unless you ARE getting a Yellow warning light" ![]() An IID can send you bonkers ![]() 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 331 ![]() ![]() |
haha !! editing |
Smitch Member Since: 05 Oct 2021 Location: North west Posts: 40 ![]() ![]() ![]() |
So the issue is still not resolved, only getting 30 miles max from an indicated zero burn 😭 I’ve got it booked into a specialist who is going to check all the dpf related parts and perform a high pressure smoke test.
Ash in the DPF has not presented enough substantial and robust evidence as a cause, and most likely not enough to give you your regen frequency on open road driving.
Thank you ☺️
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
If it is the modified arm with no nut on the top it should be fine.
Fixed … finally 🥳
Fantastic news, well done.
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3550 ![]() ![]() ![]() |
Great news - that new pressure sensor ws irking at me, there are very fw that have had to be replaced plus as we discussed calibration in the WM is not straightforward. Great shout and well done.
Posting an update as sensor failure is unusual but I have some info that might be interesting.
To confirm if anyone needs to replace the sensor then only use 6g9n-5l200-aa dp1000
Excellent news! Invaluable information for future reference for folks |
