![]() | Home > Maintenance & Mods (L322) > What to do if your DPF is blocked... |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3823 ![]() ![]() ![]() |
Yes I have told Pat about it in an email, and at the same time I suggested that the “ quit “ word could do with being in a slightly bigger font because it isn’t very easy to read , but your point about iPad orientation is worth me trying. because I have only ever used it in portrait .
Caesium Member Since: 21 Sep 2021 Location: Essex Posts: 454 ![]() ![]() ![]() |
My “Quit” disappeared and I had to exit the app completely at the end. I’ve noticed that a few times that the exit method for certain functions has disappeared Christian.
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
you must have another leak Cheers, Greg
Don’t forget to check the hose on the throttle body is well sealed.
If it's ash then a regen or forced regen would never clear it in the first place. 2012 TDV8 Vogue (L322) |
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 335 ![]() ![]() |
Almost certainly another leak. Possible cracked inlet manifold. Clean the MAF and MAP sensors in case one is clogged and its massively over-fuelling (unlikely but an easy one to eliminate). Then go for a high pressure smoke test. Because the DPF presents the problem, it is easy to think it's a DPF issue, but the reality is that's rare. Most DPF cleaning doesn't do much and is generally undertaken by people who drive short distances/mis-purpose the vehicle. For example Land Rover DPF issues increased dramatically over Lockdown as people drove shorter distances. Only one person on this forum has, ever, replaced the DPF and Cat, because that car had been driven through a deep salt water ford then parked for ages. . Last edited by Range Rover L322 on 21st Nov 2021 4:45pm. Edited 1 time in total |
Smitch Member Since: 05 Oct 2021 Location: North west Posts: 40 ![]() ![]() ![]() |
Give it a good clean, inside and out, then refit, but bend the spring wire circlip to give a bit more tension on the throttle body.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4334 ![]() ![]() ![]() |
How’s the green lipped seal inside? I bought a whole new unit and it was still a little loose on fitting. Do the spring trick as BB said Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
The seal looks ok but after removing, cleaning and bending the clip so the ends overlap (pre fitting) the soot levels are still climbing at a stupid rate. It seemed to be ok until about 5 mins in when I got on the motorway then it started climbing at a rate of about 1g a mile.
1g per mile is definitely a leak.
Replaced the hose with a new one today definitely noticing a difference.
I have watched the soot gain every mile live for 10,000 miles on all kinds of driving. I have been a bit obsessed with it. There are usual patterns like a quick soot gain after a burn.
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1306 ![]() ![]() ![]() |
I feel sorry for you guys having regen problems. I have had my car for 2 years and I know I have only done about 9000 miles in that time but it has done a regen just once. Could it be the oil you are using? I have only used the recommended Shell Helix Ultra AF-L.
