![]() | Home > Maintenance & Mods (L405) > SDV8 Oil Level Sensor Failure Preventative Maintenance |
recordman Member Since: 08 May 2013 Location: Kent Posts: 116 ![]() ![]() ![]() |
Mine went in to my dealer earlier this year to have this mod done under warranty. I wonder if they were as conscientious as you Kev, I've got my doubts!
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2566 ![]() ![]() ![]() |
LR have initiated a campaign to fit the harness to the SDV8 engine in all L405 and L494 regardless of age. |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 771 ![]() ![]() ![]() |
I assume that only applies to vehicles under warranty though Graeme? Kev
It has been showing on Topix for MY13 L405s. |
Yes, of course. As per the N357 is a service instruction, it applies to all SDV8s across all VIN ranges.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
Mine was called a “Recall” by the dealer when I said I wanted it doing. All done FOC, granted mine is under warranty. it is technically a TSB so as you say I doubt it would be covered, however as a do it while it’s in for a service job, it would probably incur a small charge for the part and 1/2 hr labour on older cars.....
It is listed as a campaign against each vehicle so should be FOC. However I expect that the campaign notice will be removed after a while even if not done, as is the usual LR practice. |
Yes, I completely agree. If it's covered under warranty, get them to do it ![]() 2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey 2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey |
jc132jc Member Since: 05 Nov 2019 Location: Suffolk Posts: 32 ![]() ![]() |
Hi all, is this easy to find? I want to check if mine has been done. |
Yes, just put your car up on ramps or stands and have a look on the sump for the sensor. Kev
M11buc Member Since: 06 May 2019 Location: Newcastle upon Tyne Posts: 44 ![]() ![]() ![]() |
I have noticed on my 4.4 2019MY that the mod has been done,. but when i checked you could see oil residue around the new wiring (not a leak as such just damp with oil) unplugged the wiring at the turbo actuator and found large amount of oil there, so cleaned out with brake cleaner and refitted for time been. i have not got any running problems or fault codes as yet, but would like to stop a problem before arises. is it a case you should just do the mod again and replace the short harness? |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1784 ![]() ![]() |
I trust JLR has investigated this properly, but has anyone had the sump off a 4.4 with this problem?
Zebedee Member Since: 09 Jun 2016 Location: Cheshire/South Manchester Posts: 386 ![]() ![]() ![]() |
I feel that the N357 service instruction and wiring loom extension is a sticky plaster over the whole issue of the oil level sensor problem.
clitheroeboy Member Since: 21 Aug 2021 Location: lancashire Posts: 4 ![]() ![]() ![]() |
Thanks for the thread link. I had the oil leak diagnosed to be the oil level sensor. I had the job turned down by my Land Rover select warranty as removal of the sump was not a major component. After reading the link to find several major components had to be removed to get to the sump, i was able to go back to the warranty company who reversed their decision and authorised the work. Which had been quoted at £1800+.
