Home > Maintenance & Mods (L405) > For the life of me I can’t work out times charging
AnnualMan
Switzerland
Ok call me and idiot but I just cannot work out how to set the car to charge at off peak hours only. Honestly having a car without an English manual is killing me.
Any advice or tips guys?
Post #662130 17th Apr 2023 6:20pm
nickt68
2015 Range Rover Vogue SE SDV8 Santorini Black
Hi Annualman, can't help with the charging I'm afraid but are you not able to view an English manual on your my Land Rover account?
Post #662202 18th Apr 2023 1:16pm
Don't know what year and model yours is as you haven't filled in your profile...
From here....
https://www.ownerinfo.landrover.com/docume...7/G2301970
This is for a 2020 model.... (others available)
TIMED CHARGING
To set a timed charging event, from the touchscreen's HOME menu select the extra features menu. See EXTRA FEATURES.
From the EXTRA FEATURES screen, select Vehicle Departures.
Touch the VEHICLE DEPARTURES screen to select a date and time for departure.
Use the up and down arrows to adjust the start time, if necessary.
Select Only… to set a single event. Select Repeating on to set a repeating event.
Select Timed Charging or Timed Charging and Timed Climate.
Select OK.
The first time a timed charging event is set, the PREFERRED CHARGING PERIOD screen displays. Use the up and down arrows to select a charging period that takes advantage of the most environmental and economical charging times.
If required, the preferred charging period can be changed via the settings menu.
 Pete
Post #662204 18th Apr 2023 2:00pm
AnnualMan
Switzerland
Thanks for the info. It’s a MY19 P400e.
I want the car to start charging at 8pm onwards. I actually tried what’s described and set a timed departure at 8pm and a preferred charging time of 8:15pm, yet when I plug the car in before 8pm it starts charging anyway!
It’s driving me nuts.
Post #662210 18th Apr 2023 5:00pm
AnnualMan
Switzerland
So I penny finally dropped….
I had to set a departure time way way after 8pm and a preferred charging window of 8pm - 7am (off-peak). 2018 P400e AB LWB
Post #662230 18th Apr 2023 8:10pm
Thumbs Up Pete
Post #662231 18th Apr 2023 9:00pm
