When mine went on my 4.4 TDV8, they found that the cooler had also warped a bit, so needed to be replaced anyway. Others have just replaced the gasket with success. I would have hoped that JLR might have fixed the issue on the L405 at some point, but don’t know if they ever did….
I had to have the coolant flushed a number of times to get the oil out. So you might need to check the coolant has not been contaminated too. You might have caught it early enough.
I’m pretty sure there is a guide to replacing the cooler in the Wiki, top right…. It’s for the 4.4 in the L322, but yours can’t be much different?
2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
