Home > Technical (L405) > L405 oil cooler oil leak down back of engine
Railtrail
New Zealand 2015 Range Rover HSE SDV8 Firenze Red
Hello all,
After many hours removing false firewalls and the inlet plenum I got to the oil cooler assy. I removed the top cooler held in place by Torx screws and found a fossilised seal. I still have to remove the plate with the oil filter on after taking out the pipe with O rings at rear LHS. My question is do I replace the whole assy or just the gaskets bearing in mind it has been a very difficult job thus far. Also down the RHS of the cooler is a pipe with a right angle bend and very tight spring clips on. I was able to remove spring clips but the pipe broke with a sharp crack lower down. Not sure what pipe this is? I live quite remotely in the south of New Zealand so it may be better bite the bullet and just put on a new genuine cooler assy. Thoughts?
Many thanks in advance. Vehicle has done 160,100 kms
Post #613108 18th Nov 2021 11:03pm
mjdronfield
When mine went on my 4.4 TDV8, they found that the cooler had also warped a bit, so needed to be replaced anyway. Others have just replaced the gasket with success. I would have hoped that JLR might have fixed the issue on the L405 at some point, but don’t know if they ever did….
I had to have the coolant flushed a number of times to get the oil out. So you might need to check the coolant has not been contaminated too. You might have caught it early enough.
I’m pretty sure there is a guide to replacing the cooler in the Wiki, top right…. It’s for the 4.4 in the L322, but yours can’t be much different?
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #613117 18th Nov 2021 11:45pm
DrRob
They can warp. Fit a whole new one.
Advanced Factors sell the Nissen one which is OEM spec IIRC
https://www.advancedfactors.co.uk/oil-cooler--filter-13921-c.asp Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
2025MY Defender D350 90 in Silcon Silver on coils
Post #613129 19th Nov 2021 8:35am
Railtrail
Hi DrRob,
Thanks for the info about Advance factors. Stuff is very expensive here generally so even one filter kit would pay for itself and shipping. 2 sets and I would be quids in!
Post #613212 20th Nov 2021 4:47am
