Home > Technical (L322) > 2003 4.4 zf5hp24 Gearbox just been serviced, Red oil used ?
b348xyx
United Kingdom 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
Hi all,
Just wanted to check something if you dont mind
had gearbox serviced at dartford transmissions as recommended alot places, as my gearbox oil pan was leaking so had mega flush done and filter change done same time.
now looking invoice noticed this.
" MN8218 - O.E.M. MULTIVEHICLE ATF - RED - JWS3309 - LT71141
which is this https://www.mannol.de/products/gear-oils-a...e-jws-3309
I have looked all these threads
https://www.fullfatrr.com/forum/topic38595-45.html
https://www.fullfatrr.com/forum/post287945.html
https://www.landyzone.co.uk/land-rover/wrong-gearbox-oil.274633/
Have they used the incorrect fluid ?
thanks
edited to add image
 2003 Range Rover 4.4 Litre V8 - Adriatic blue
2003 Range Rover 4.4 Litre V8 -Maintenance History Click Here = http://www.fullfatrr.com/forum/topic39687.html
Post #613091 18th Nov 2021 9:48pm
Gsxr1250dave
Not sure I will check mine tomorrow I'm sure what I put in wasn't red iv got a few litres left of what I used when I changed mine.
Post #613096 18th Nov 2021 9:56pm
dhallworth
I helped a friend change the gear oil in his when it needed doing. He used LT71141 and I’m 99.9% sure it was straw coloured. If someone has put red oil in yours then it sounds like it’s the wrong oil.
If it were my car, I’d be wanting that oil out pretty damn quickly and not using it until it was out.
Post #613098 18th Nov 2021 10:10pm
b348xyx
updated with part invoice. 2003 Range Rover 4.4 Litre V8 - Adriatic blue
Post #613099 18th Nov 2021 10:18pm
dhallworth
JWS3309 and LT71141 are two different fluids.
I wonder if they’ve used an aftermarket oil that claims to meet both specifications.
Post #613105 18th Nov 2021 10:31pm
b348xyx
https://www.buycarparts.co.uk/mannol/15768409
This is the oil I think.. MANNOL Multivehicle JWS, O.E.M. 8218 Automatic Transmission Oil
JASO M315 Type 1A, Allison C4, AISIN WARNER JWS3309, JATCO ATF, JATCO 3100 PL085, TOYOTA ATF Type T, TOYOTA ATF Type T-II, TOYOTA ATF TypeT-III, TOYOTA ATF Type T-IV, NISSAN/INFINITI, MATIC D, MATIC J, MATIC K, NISSAN/TEXACO N402, (JATCO FWD), MITSUBISHI DIAMOND, SP-II / SP-III, MAZDA ATF-M III, MAZDA ATF-MV, DAIHATSU ALUMIX, ATF MULTI, HONDA ATF-Z1, (not for CVT), ATF DW-1, SUZUKI 3314, SUZUKI 3317, SUZUKI 2384K, SUZUKI ATF OIL, ATF OIL SPECIAL, SUBARU ATF, SUBARU ATF-HP, HYUNDAI/KIA SP-II, HYUNDAI/KIA SP-III, IDEMITSU K17, MOPAR AS68RC, GM DEXRON IID, GM DEXRON IIE, GM DEXRON IIIF, GM DEXRON IIIG, GM DEXRON IIIH, CHRYSLER ATF +3, CHRYSLER ATF +4, VW/AUDI G 052 025-A2, VW/AUDI G 052 162-A1, VW/AUDI G 052 990-A1, VW/AUDI G 052 990-A2, VW/AUDI G 055 025-A1, VW/AUDI G 055 025-A2, BMW 7045E, BMW LA2634, BMW LT71141, MB 236.1, MB 236.2, MB 236.3, MB 236.5, MB 236.6, MB 236.7, MB 236.9, MB 236.10, MB 236.11, PORSCHE JWS 3309, VOLVO 97340, VOITH 55.6335.XX, ZF TE-ML 03D, ZF TE-ML 04D, ZF TE-ML 11B, ZF TE-ML 14A, ZF TE-ML 14B, ZF TE-ML 16L, ZF TE-ML 17, FORD MERCON V, FORD FNR5, MAN 339F, MAN 339 V1, MAN 339 V2, MAN 339 Z1, MAN 339 Z2
I will have to call and ask but most likely will get "it meets the OEM spec" 2003 Range Rover 4.4 Litre V8 - Adriatic blue
Post #613106 18th Nov 2021 10:34pm
Gsxr1250dave
This is what I used, it is straw coloured NOT red
https://www.ebay.co.uk/itm/ATF-LT-71141-Sy...635-2958-0
Post #613124 19th Nov 2021 1:21am
DrRob
They are one of the best in the business for LR transmissions so I doubt it very much they put the wrong fluid in.
In their defence, I would have called them first to ask rather than post on here Whistle
https://www.mannol.de/create-pdf/272/en is the oil
Did they rebuild the box or did you take it to them following a rebuild elsewhere I wonder who used red oil? Whistle Rolling Eyes Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #613128 19th Nov 2021 8:33am
b348xyx
Hi, I totally agree which I why I wanted to ask on here first as not said bad word they did the job and they are well recommended just put me back a little when reading the red fluid was used.
as when doing my research, everyone says fluid which is rated Dexron III and LT71141 is not really the correct to use.
Of course I am no expert which is why I am seeking advice here. hoping RRphil will jump in and comment.
The gearbox was rebuilt under Warrenty 09/2018 @ just over 111k, by another garage. reason for recent work was leaking gearbox oil pan, and I believe oil was low in gearbox
and of course this could be a non issue, but rather know now instead having issues and in back my head thinking if its the fluid. 2003 Range Rover 4.4 Litre V8 - Adriatic blue
Post #613132 19th Nov 2021 9:34am
Billie
England 2006 Range Rover Vogue 4.2 SC V8 Buckingham Blue
Gearbox oil
Interesting, our car was running perfectly (don't fix if it ain't broke comes to mind) we decided to have a full service, also engine and gearbox oil change. Since then we have been having gearbox problems when the engine is hot. When cold no problem. After about a twenty mile run, if we switch off we are then unable to start for about twenty mins. When it starts, it's perfect again with no faults shown.
Last week we were stuck in "P" at a garage after filling up for nearly half an hour Embarassed Embarassed Embarassed
Post #613135 19th Nov 2021 10:13am
DrRob
Call and chat to them I would Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #613136 19th Nov 2021 10:23am
