Home > Technical (L322) > 5.0 S/C . Damaged Throttle Body Wiring
alx
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Nara Bronze
Hello,
Can anybody help with the wiring for the throttle body plug that was damaged during the s/c removal? It appears as if the plug was repaired in the past and perhaps cut a bit too close to the pins causing tension which has now resulted in 3 pulled wires (see pic).
I'll depin the plug and recrimp with possible extension, just need to know which one goes where. So perhaps a picture of your own plug is all I'm after.
Many thanks!
Post #612408 12th Nov 2021 12:25pm
Piet
Netherlands 2008 Range Rover Autobiography 4.2 SC V8 Lucerne Green
Did the bearings in the SC snout today.
So I took a pic of mine.
But……..mine is a 4.2 so take care.
Have nice weekend, regards Piet
Post #612511 13th Nov 2021 1:48pm
alx
Thanks Piet. Obviously not the same colouring between the two models but if I had to guess it, I'd go with brown, blue and yellow to match brown, orange and yellow in your picture. Hope I don't fry the TB!
Post #612697 15th Nov 2021 10:49am
alx
So as my luck would have it, this wouldn't work. However I was able to find some reference on the Jaguar forum for the TB wiring which I attach to this message in case someone else comes across this thread in the future and needs the correct wiring information.
PS: Pay attention to the pin numbers as they are in a different order to how they are pictured. I've since changed the wiring to match the diagram and the TB works as it should.
Post #612880 17th Nov 2021 10:52am
Piet
Good find.
Nice its sorted Thumbs Up Thumbs Up
Post #612922 17th Nov 2021 4:09pm
