![]() | Home > Technical (L322) > TDV8 Complete Engine Failure |
Van Diesel Member Since: 27 Oct 2013 Location: Norfolk Posts: 183 ![]() ![]() ![]() |
Pm'ed |
Emperor Mong Member Since: 07 Jul 2010 Location: London Posts: 1435 ![]() ![]() ![]() |
Me too. |
DavidC Member Since: 08 Oct 2012 Location: Beds Posts: 66 ![]() ![]() ![]() |
I use a LR trained indy in my village which should not be too far away from you.
Bryan N Member Since: 01 Jan 2014 Location: Cambridge Posts: 68 ![]() ![]() ![]() |
David, thanks.
Simple1 Member Since: 01 Jun 2013 Location: Somerset Posts: 112 ![]() ![]() ![]() |
Only just caught up with this thread. Almost a year to the day my 45000 mile Sport did exactly the same and after a fuve month battle with LR to get an engine and a contribution I eventuLly got one with 85% contribution from LR. Had car a day and backed it with a strange rattle which was eventually diagnosed as the torque converter not done up during heRt transplant. Cause of failure was turbo exploding and pumping 7 lts of oil into exhaust. Turbo was less than 10k miles old TDV8 Vogue SE 2009.
dysynni1 Member Since: 05 Jun 2013 Location: Moscow Posts: 2 ![]() ![]() |
I thought I would add to this topic rather than start a new one. My TDV8 (09MY) had exactly the same issue (loss of power, smoke, engine would not start). It was relayed to the garage and they said that both turbos had gone. In one the seals had failed, which drained the oil, causing the other one to seize. New intercooler required as well. Fortunately the engine was OK. Bill just shy of 5K. The car has done 118k miles (Vogue SE). I asked what I might have done wrong, and was given the usual "always do your services at a main dealer". I had the Inspection 1 done at a dealer in August. Mechanic said that the turbos should last several hundred thousand miles and could not explain why the seals had gone. Slightly frustrating.
Good reason to have a decent warranty.... |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3194 ![]() ![]() |
@ gary elliott
We use the best available WARRANTYWISE plan depending on age and mileage.
Mr John Paul Billson Member Since: 27 Oct 2021 Location: Northants Posts: 6 ![]() ![]() |
Hi I have just read this post, sorry it it a 3.6 v8 or the 4.4. Thanks Paul |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3550 ![]() ![]() ![]() |
Very first post says 2007
Thanks, I am having similar issues with my 2015 4.4 at the moment and thought the problem may be the same, but as you say 3.6, I'm not sure now. thanks anyway. |
