![]() | Home > In Car Electronics (L322) > 2010 to 2012 satnav information gathering |
Cudman Member Since: 28 May 2018 Location: Undisclosed Posts: 15 ![]() ![]() |
Yes and no. No, it cannot be used for the unlock. You will need to use a DOS tool (HDAT2) that sends direct IDE commands to the device. That tool will only work on a native IDE controller, preferably as old as possible. Think Intel PIIX4. Yes. It will work when you after unlock need to manipulate the map data like copying over updated map files and editing content of the license file pair if you want to change region. Best done on a modern computer with a nice SATA/IDE adapter on an USB3 dongle, or direct on your SATA port. |
Johnfin Member Since: 18 May 2021 Location: Lyon Posts: 8 ![]() ![]() |
Hi Cudman, et Al.,
No, I told others what I learned. I did not keep it a secret. Land Rover is not going to come home to your car and update it so that it no longer can be unlocked. They don't care about these old cars, they only want to sell the new ones. If they cared they would offer support to update maps that they offered for purchase. So all of the people reading this thread basically has been without any support for all these years while some people knew how it worked, and kept if for themselves. That sucks.
Yes, all cars apparently have the same IDE 40GB drive. I've seen some Jaguar forum posts where somebody apparently had a SATA drive, so clearly the nav computers got updated along the way. Mine is a 2011 and it has the DNNS035 part no. Would be interesting to learn what part number was used there but seeing as some peopel don't share information well we might not know.
SLOT3 is WEU or Western Europe (corresponds to Volvo DVD A Austria, Belgium, Czech Republic, Denmark, Finland, Germany, Italy, Liechtenstein, Luxembourg, The Netherlands, Norway, San Marino, Sweden, Switzerland, Vatican City State. SLOT4 is EEU or Easter Europe (corresponds to Volvo DVD D Albania, Austria, Belarus, Bosnia and Herzegovina, Bulgaria, Croatia, Czech Republic, Estonia, F. Yugoslav Repub. of Macedonia, Germany, Greece, Hungary, Latvia, Lithuania, Moldova, Montenegro, Poland, Romania, Serbia, Slovak Republic, Slovenia, Ukraine SLOT 5 is RUS or Russia, can also be Australia depending on market SLOT14 is TUR or Turkey, can also be Argentina depending on market The other slots I do not know what they are used for, but maybe you who have had the journey could enlighten us?
Mine has 0650 / 6A05. Why not share the 660 to the forum or on a link if not possible to attach? Was it the same in SLOT0 as in the map partitions?
You can not take the MUINFIEE.BIN from one slot to another. It has to be the one in the enabled folder to open up the maps. Then the nav system actually doesn't care what map data is in the folder. I know because I updated the maps by replacing the old maps in the one enabled folder. Just keep the MUINFIEE.BIN and UPDATE.INF intact as they both share the same info. However, if you want to move from one region to another you will need to copy the maps from another region into the enabled region folder, then patch the first four bytes in that pair of files effectively changing the date of the maps. In my experience the original maps must stilll be kept in one other SLOTx folder in order to be recognized as having been "updated".
Yes, apparently there is. See above.
No, it doesn't matter. You resize the partition, the SLOTx of the active map to fit larger maps. The FAT32 system allows files up to 4GB in size. Even the newer 2012-2016 Discovery 4/LR4 nav system uses the same FAT32 file system and single files are not exeeding 4GB, about 2-3GB yes but not larger. The *entire* map folder can be bigger, like 28-30GB but that is not exceeding the single file limit of 4GB. If you need to put custom countries into a map folder you can do that. Have you used Kiwi File Explorer? There are people driving around with custom maps in their cars, they just don't share how they do that using the KFE and its associated tools for exporting and importing map data because nobody knows that it can be done and thus ask. |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3550 ![]() ![]() ![]() |
so there's a secret group of map hackers not sharing? Thank you Cudman. . Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
Do we have someone more versed on legal side to make sure we're not running into trouble with LR?
Re newer map versions. Well, let's refrain from sharing links here as there are copyrights on the map data.
JamesDarby Member Since: 29 Sep 2021 Location: Rugby Posts: 24 ![]() ![]() ![]() |
Following along with interest.
To those who would unlock the HDD, would be great if you could provide your MUINFIEE files to run some additional analysis - more examples better as there needs to be a patter - just need to discover it. There needs to be a relatively simple logic around it.
MartinD Member Since: 20 Oct 2010 Location: Edinburgh Posts: 303 ![]() ![]() ![]() |
This all seems right up my street so I'm following with interest from a technical side.. And the fact my maps are as old as Moses. 2011 4.4 TDV8 Vogue SE - 'Black Betty'
So I have not got my FFRR and its got a 2011 map in it.
roadnutter Member Since: 19 Sep 2013 Location: Bridge Of Weir Posts: 23 ![]() ![]() ![]() |
Hi, has there been any progress on this? I'm happy to help if others are interested in finding a way to maintain an up to date sat nav map on these cars? Mine is a 2012 with single view and maps from 2011. Only 11 years out of date! I'm a developer so could help debug the map data and quite willing to try things on my car. Cheers James
No progress made, as would need some more souls interested and actively participating to move forward - I've potentially reached limits of knowledge/time effort spent on it. Majority of important findings is already above - if one is happy to engage in development of maps transcoding - happy to work on it together. |
I'm not sure how many JLR techs are on this forum, certainly through other issues raised and extensively discussed it seems we don't get any insider info, not ever dealer tech types. So I suspect none or if they are here they don't give it up. . Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
The best would be to have that disk to see how files are laid out.
