Home > Maintenance & Mods (L322) > Final Stage Blower Resistor Replacement
Page 4 of 4 <1234
J2B
England 2010 Range Rover Vogue TDV8 Ipanema Sand
Just going to tackle this at the weekend as mine has just started to play up, glad i looked on here for pointers, Landrover wanted £121.52, got the self same genuine part at Island 4x4 £95.99 inc vat and delivery, hope i don't swear to much while doing it Laughing Laughing
Edited, completed within 30 minutes. Thumbs Up
Post #588083 19th Mar 2021 11:14pm
Merchy
Quick question to those with more experience of FFRR's than me ( 3 years, years with my first one ) at 94000 miles on the car, I have had very little in the way of electrical gremlins. Am I lucky?
Would those with more experience recommend changing this BEFORE it fails, ( Due to mileage and age - 15 years old ) reading about how many fail, I am tempted to buy one and keep it as a spare in the garage just in case.
Not very expensive, and not a major job to change.
Having written the above, I know what will bloody fail tomorrow. Thank you gents.
Post #588094 20th Mar 2021 1:16am
bgennette
Australia 2003 Range Rover HSE Td6 Java Black
Useful Information when changing the FSR
A couple of things that not one of the many videos or how-tos bothered to tell us -
The FSR cooling pins face transverse, across the car, from right to left (when facing forward), so
the FSR comes out by pulling towards the right hand side.
So the panel on the right side of the centre console has to come out
1 x torqs 20 at front, 2 x transverse press clips at rear
The 'finisher' panel beneath the dash does have to be removed in order to get your hand in.
4 x torqs 20. If right hand drive may also have a large 3 blade twist plug; use a 6mm flat screw driver to undo
The mounting aperture is in the large, near vertical heating duct that is almost touching the engine compartment wall, so
the FSR's power plug is ~40mm from the wall and ~50mm above the angled heating duct
If the FSR releases easily the ducting across the top of the footwell does NOT need to be removed, just pulled aside, if ...
The 'release' tabs for the power plug stiffen up over 10-12 years, so
you may need a 'U' shaped wire probe to release them from their clip ends in conjunction with squeezing in the tab tops front and rear
The hold-in claw on the FSR is at the top, very close to the engine wall when it is clipped into the duct, so
applying a clockwise twist while pulling out will help to release it. A wide, flat screw driver may need to be applied into the power socket to give the twist to persuade the FSR out of its aperture
The stiff tabs also make refitting difficult, so
fitting the plug to the new FSR and forcing the FSR into the aperture may require a 200mm long drift and a rubber hammer
Now that I know exactly where it is located and how to change it I estimate that the job would only take ~20 minutes from gathering the tools to washing your hands at the end.
So the real, complete tool list is -
Soft mat (for kneeling on the ground next to the car)
Torch
Torqs 20
6mm wide flat screw driver, and maybe a wider blade too
200mm long drift
rubber hammer 2003 TD6, EGR delete, vortex crankcase breather update, performance chip, UHF 2 way, Android head unit, crash camera on dash, always-on rear view camera to mirror screen, LED DRL`s, Electric trailer brake controller. FSR replaced. Pulling 3T caravan all about Australia
Post #609768 20th Oct 2021 8:36am
bgennette
What exactly is an FSR ???
While I'm here I thought I'd explain what this 'Resister' thing actually is.
In the early days of auto electrics, stepped fan control was via a series-string of big power resistors built into an almost complete circle. +V power came in at one end and a rotating contact selected the voltage available at any of the junctions between the resistors. If the contact went to before the first resistor the the full voltage went to the fan, if contacted after the first resistor some voltage is turned into waste heat by the resistor and a lower voltage goes to the fan. Turning the contactor further along the series created more waste heat and lower voltages = lower speeds. Turned past the end of the resistors no voltage is connected = Off. Because they got very, very hot, often the resistors were placed in the engine compartment and operated by an extension shaft from the dashboard.
In the 1980s the big resistors were replaced by much smaller ones to produce low power voltage steps (0, 2-->8V) that were then applied to an electronic throttling device to feed higher power to the fan. Electronic throttling devices are called Transistors. Bi Polar Transistors can switch quite high voltages, but their control input must be between 0 and 0.7V so a small integrated circuit translator is needed between the control resistors and the power transistor. These Power Transistors also get hot as they reduce the voltage, but not as hot as the older power resistors, AND all the heat is produced in a single, small, fixed location. To transfer the waste heat away from the Transistor into the air a large metal plate with lots of pins (to provide a large surface area) is clamped onto the transistor body. This is what the BMW 1990s to 2010s FSR is. The control knob works the first stage resistor, the translating IC is intermediate and the Power Transistor is the actual, Final Stage Resistor.
Much more efficient Field Effect Transistors that can handle large amounts of power became available in the late 1990s. And along with their introduction a new method for speed control became popular - deliver small (micro second), full power pulses to the fan motor and allow it to coast between pulses. Shorter pauses = faster speeds. The mass of the motor and fan blades will smooth out the speed and the transistor always switches from full Off to full On, therefore greatly reducing waste heat. This is what BMW uses now.
The original 'hedgehog' FSR has a voltage converter IC (Elmos 10901D) with simple over heat monitoring, an over current detector that shunts the voltage control signal to ground (thus turning off the fan and signaling the controller) and power transistors mounted underneath the circuit board (3 pins in red circles) under the black resin. Over time the heat cycling breaks the solder joints with the sensors and transistor control pins, etc leading to full-on continuous running or total failure. Its heatsink has just a few, long, large heat exchanging pins.
There have been a few versions of the circuitry over the years, from BMW and others.
The currently available, upgraded version includes a microcontroller to better manage the system, including shutting down if the transistor starts to overheat. The transistor is flat mounted through a hole in the top of the circuit board with an all copper connection to the heatsink which on this model has lots and lots of smaller pins to provide ~2 times the heat exchange surface area. This 'improvement' has just one small problem, the microcontroller is mounted close to the heatsink and so it gets hot ... and fails in all sorts of 'interesting' ways.
Around 2014 an American company produced a hybrid FSR (APSX WB FSU). Its microcontroller accepted voltage step input and sent pulse/coast signals to a pair of FETs which required no heat sink pins. Failure of these is rare. These are no longer available Crying or Very sad With todays cheap electronics I think a similar DIY solution is viable. But I don't have enough information about the type of voltage signal used (bi-directional) nor the power rating for operating the fan ... can anyone supply this? Does anyone have one of the hybrids to experiment with ?? Or maybe someone from APSX can make the details public ???
Because European vehicles operate with (to them at least are) extremes of temperature (cold winters and hot summers), vehicle fans are usually run at moderate to fast speeds with very little waste heat generated in the FSR. So not a problem for BMW. Except not all BMWs operate in that climate, for instance in Australia, after reaching a comfortable temperature, we mostly have the fans just moving the heated or cooled air slowly through the system so the FSR runs very hot, and doesn't last so long. I'm sure vehicles in the southern US have a similar profile.
There are many 'interesting' failure modes for the FSR with always On being the most common. Many of the controllers in a BMW monitor the operation of other controllers and Fan ON while engine is Off can result in wierd results. In my case the cabin air sampler fan never stopped, the indicator flashes at lock and unlock didn't happen, air suspension often had to be reset and the battery got flattened randomly.
And now you know.
bye 2003 TD6, EGR delete, vortex crankcase breather update, performance chip, UHF 2 way, Android head unit, crash camera on dash, always-on rear view camera to mirror screen, LED DRL`s, Electric trailer brake controller. FSR replaced. Pulling 3T caravan all about Australia
Post #610115 23rd Oct 2021 12:56am
Mullaca
England 2009 Range Rover Westminster TDV8 Stornoway Grey
Update re 2009 Westminster TDV8
Just replaced my FSR due to total lack of climate fan and therefore a/c or heating. Many thanks to all contributors on here, other forums and various YouTubers, I bought a Chinese copy off Amazon UK for £21.99 and fitted it relatively painlessly using all the advice I'd read.
One point of note is that on my RHD car, the foot-well heating duct is held in place by 2 torx screws which
I haven't seen mentioned anywhere else. getting these out was by far the most frustrating part of the job, having to maneuver the torx driver into the spaces above the pedals and behind the fascia panel below the steering wheel. Once those screws were removed, the duct simply drops out of the way without any complex manipulation as mentioned elsewhere.
Immediately I plugged the new FSR in I tested and my climate control was fully restored.
Clearly now need to hope that a faulty fan is not the cause of the FSR failure as described elsewhere, as I don't look forward to cutting holes behind the dash facia to replace the fan.
Post #669792 25th Jul 2023 4:33pm
rik__
United Kingdom 2004 Range Rover Vogue Td6 Zambezi Silver
2004 Vogue
Sorry to bring back this thread guys ive just replaced mine as fans were dead all worked fine for about 5 mins i turn the car off and the fans were still running. flicked the car back on and stayed running and stopped responding to the controls (fans speed stayed at 100% no matter what i did. could i of a got a faulty one?
Post #690986 20th Apr 2024 5:45pm
pcourtney
maybe
@bwelton had this earlier on in this thread, 15th Feb 2021, he replaced it with another new FSR and all back to normal, also check the actual connector, maybe it needs a clean with electrical contact cleaner, it could need replacing as well !
Also be aware that there are two types of FSR for the L322 ( years 2002 to 2012 )
The photo below shows the smaller triangular version that I have in my 2004 Vogue
and the larger more rectangular shaped on that I have in my 2011 Vogue
Post #690990 20th Apr 2024 6:47pm
steve.north0069@icloud.com
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Galway Green
Although new to Fullfatrr I acquired my 2011 L322 TDV8 4.4 two years ago and after a general overhaul to bring it up together, what a machine!!! Best decision ever.
Though it has handed me a few head-scratchers lately...a couple of days ago the blower decided, all on its own and without any help from a grownup, to go to maximum power. When I turned off the ignition at the end of my (windswept) journey, the blower stayed on!! I had to disconnect the battery to turn it off.
Fearing the expensive worst I removed the climate control unit in the centre console completely, disconnecting the various plugs and wires. Made no difference! I re-connected the battery with the console disconnected, and there we were, back on full blower....
Could this be a Final Stage Resistor fault? Any clues or pointers greatly appreciated!!!
Post #701281 2nd Oct 2024 12:03pm
rik__
That's exactly what happend to mine after a fitted a cheap one, fans on 100% no matter what replaced with a good one and happy days
Post #701392 3rd Oct 2024 4:46pm
Hi thank you that's great. I bought one from Amazon its got mainly 5 star reviews but suspiciously cheap at £26...will update when fitted and also provide a link if the part actually works!
Post #701393 3rd Oct 2024 5:08pm
Bolert
United Kingdom 2012 Range Rover Autobiography TDV8 Santorini Black
Good to know if mine ever decides to have a mind of its own!! Rolling Eyes 2012 4.4 TDV8 AB Sumatara Black with Ivory / Jet interior
Post #701562 5th Oct 2024 6:45pm
Paul H
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Stornoway Grey
Apologies for resurrecting an older thread but am looking to replace my FSR and looking at all the threads it seems a relatively easy job to do if you are double jointed and have long fingers.
The part that is worrying me is the reference I keep seeing to 2 types of FSR, the JLR parts site only quotes one part number JGO000021 and it seems to be the 'triangular' shaped one but a few sellers on Ebay seem to reference that there are 2 styles fitted and have images of the squarer one and say to check which one you have before ordering.
Is there anyway to check which one I have fitted without physically removing it or do they both fit and one is merely a variant of the other? 2011 L322 Autobography - a lot of bells and some of the whistles...owner with no idea!
Post #709847 21st Jan 2025 9:26pm
You will probably have to have a look see, just in case your 2011 was before or after the changeover. It will be good practice for fitting the new one. .
Post #709854 21st Jan 2025 10:21pm
FJ12Jagmen
United Kingdom 2007 Range Rover Vogue TDV8 Santorini Black
Replaced heater blower motor today after digging a big hole in the middle of the dash. Wanted to test it before I put everything back together. Re-connected the battery, ignition on, lights on climate control but no fan action.
Replaced FSR but no change. Now dark and damp so will try again tomorrow.
Do I need to wire in the infotainment and everything else before the fan will work? 2007 3.6 TDV8
1979 Mini Special
1988 Yamaha FJ1200
!952 BSA Gold Flash
Post #712527 22nd Feb 2025 7:20pm
Page 4 of 4 <1234
