Home > Maintenance & Mods (L322) > Final Stage Blower Resistor Replacement
Page 1 of 5 12345>
dan_uk_1984
Last weekend I had to replace the blower resistor. It's a complete DIY job but needs lots of patients as you're up to your elbow in the dash with what seems like your arm bent in 5 places. Temptation to throw the little hedgehog across the drive runs high sometimes as you try and wiggle it in! Overall took me about 30 mins to get the trim panel above the pedals off, the panel inc wood off the trans' tunnel and get the old one out and the new one in and then put the trim back on.
This little gadget receives a full 12v from the battery and then steps it down to different voltages to allow for the different fan speeds. Being a resistor the excess voltage has to go somewhere and as such it gets very hot, hence the massive heat sink it is also installed in the path of cold airflow otherwise it would overheat. It's at its hottest when the fan speed is at its lowest so generally spends most of its time at its peak load (low fan speed)
It seems a common component to fail, no surprises to learn that it has a big fat BMW sticker on it (so far the only parts that have failed on my car have been the superior BMW components) I suspect that it is just poor design and that every one will eventually fail. Mine went at 110,000 so in working hours its done a fair run.
Replacements aren't expensive, I paid £39.00 inc p&p off ebay for a pattern part which I didn't think was too unreasonable.
Replacement unit (the original ones have much longer spines, but this one has more of them):
Instructions:
Post #5605 16th May 2009 3:43pm
StevieH
Dan
No surprise mate, my vehicle of choice before the FFRR was an MG ZT which funnily enough was basically a BMW 3 series with a decent looking body on it (tractor juice model before you all start shouting about pants K series engine). Every component that failed was either Bosch or BMW. . . .WTF how did we let such a shower of Censored drive the British motor industry into the ground Crying or Very sad
Post #5612 17th May 2009 1:18am
Monty
I bought mine direct from LR for under £20 probably worth checking with them.
Post #5619 17th May 2009 12:53pm
dan_uk_1984
Bargain, which dealer was that from? Ottons in Salisbury wanted £75 + VAT when I rang them! Still hopefully this pattern part will actually be an improvement on the genuine one.
Post #5620 17th May 2009 1:47pm
Monty
Williams in Manchester 0161 232 5000
Post #5623 17th May 2009 5:20pm
dan_uk_1984
Well, as my unit failed after 9 months I'll be giving Williams a call as per above to see if they can still supply the part for £20!
D
Post #14738 11th Mar 2010 9:08pm
elpeede
England 2003 Range Rover Vogue Td6 Zambezi Silver
http://www.rswsolutions.com/index.php?opti...;Itemid=73
Some more piccys on the linked site. Hope it helps. I found this trying to work out my fan issues which I have still to get to the bottom of but I think I can elimainte the final stage resistor.
Lee
Post #14739 11th Mar 2010 9:12pm
dan_uk_1984
Thanks fella, when I did it the first time I figured it out the hard way, also I ended up cutting the ducting to get in there propperly.
Will order one tomorrow and pop it in one evening, I'm thankfull for the slightly longer days now. Bring on the warmer evenings!
Dan
Post #14740 11th Mar 2010 9:15pm
IanV8
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
£20.67 for mine from LR in Kings Lynn.
There are two types one for the rear and one for the front they are not interchangeable as I found out.
Ian
Post #14880 15th Mar 2010 2:12pm
SGW
United Kingdom 2009 Range Rover Autobiography 5.0 SC V8 Stornoway Grey
Dan, I don't know if this applies to all parts. I fitted a new radiator, it failed within 12 months when I went back to the parts dept of the main dealer to order a replacement under warranty they told me they would fit it free of charge. Maybe worth a try.
Stewart.
Post #14910 15th Mar 2010 11:00pm
andyw
England 2002 Range Rover HSE 4.4 V8 Zermatt Silver
Quote:
[Well, as my unit failed after 9 months I'll be giving Williams a call as per above to see if they can still supply the part for £20!]
dan
how did you no it had failed, did you check or did your battery go flat
cheers[/quote] 02 Range Rover HSE Zambezie silver 4.4
Post #14912 15th Mar 2010 11:39pm
dan_uk_1984
Stewart.
Thanks, unfortunately the first one was from eBay rather than a main dealer. It's not too difficult to fit though to be honest. 30 mins really and that's 25 mins of removing the trim.
andyw wrote:
dan
cheers
The first one failed at the beginning of last summer, I think because it sits in the air stream to stay cool the air was warmer in summer so it heats up and then fails. Basically when the fan should be on all of a sudden the fan will go off, but the blobs are all still lit up on the display. This exact same thing has happened now, on a frosty morning it will be fine, but if it's remotely warm then it doesn't work.
Post #14916 16th Mar 2010 8:53am
Here's my take on replacing the blower resistor
http://metricrat.co.uk/replacing-the-final...kiii-2002/
(Edited old link Thumbs Up )
Post #17626 29th Apr 2010 12:43pm
dan_uk_1984
New car = new faulty blower resistor!
Post #32542 20th Oct 2010 3:36pm
Thats bad luck mate I thought you would have checked that little blighter Big Cry
Post #32543 20th Oct 2010 4:01pm
Page 1 of 5 12345>
