![]() | Home > General > L322 4.4 TDV8 Longevity |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7906 ![]() ![]() ![]() |
But then you’d be doing the mileage in a cheap runaround…. Sort of defeats the object of having a nice comfortable car. Had it been something rare, I’d have agreed but I couldn’t think of another car I’d rather do the miles in.
At m-way speeds the engine is only slightly above idle speed so it will run for ever as a long distance mile muncher. Short urban trips will be much more life limiting on a DPF diesel. 2012 TDV8 Vogue (L322) |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4332 ![]() ![]() ![]() |
Keep on driving it and don't worry Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 696 ![]() ![]() ![]() |
Oil change.......oil change......oil change.......oil change = high mileage mile muncher.
Goodluck247 Member Since: 08 Jan 2021 Location: London Posts: 30 ![]() ![]() ![]() |
Likely me just over-worrying! Thank you all, considering the mileage I think I'll go for 6 monthly oil changes now. |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1210 ![]() ![]() ![]() |
I think you are better off with a car that has covered the correct mileage or higher? then with a car that has low milage city work only?
