![]() | Home > Technical (L322) > centre console switch |
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 331 ![]() ![]() |
Have a look around the front grill and see if there is a radar jammer. Mine had one when I bought it. The fines are stiff for them so I whipped it and all the wiring out pronto.
Rog21 Member Since: 09 Nov 2018 Location: Havant Posts: 62 ![]() ![]() ![]() |
dont thinks its that as it looks like it was designed to be there as its built into console. L322 4,4 TDV8
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7865 ![]() ![]() ![]() |
Have you got a pic?
Pic of switch in middle. L322 4,4 TDV8
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35487 ![]() ![]() |
could be anything....try following the wiring.. ... - .- -.
That’s not factory fitted, but looks tidy. As Stan says, need to follow the wires.
The side panels near the climate controls pop off easy enough, so you can see the front of the centre console, but as you say, bit of a big job to go further….
Solved
That sounds like a good plan. Least you know.
