Home > Technical (L322) > centre console switch
Rog21
England 2012 Range Rover Vogue TDV8 Buckingham Blue
A silly question but I have a switch inside the centre console next to the USB and lighter sockets, they work which ever way the switch is set.
Does anyone know what its for ?
Rog L322 4,4 TDV8
Freelander 2 sold
Honda Transalp
Sunbeam S7 deluxe (in bits)
Sunbeam S8 (restoring)
Post #609185 14th Oct 2021 6:01pm
Range Rover L322
Have a look around the front grill and see if there is a radar jammer. Mine had one when I bought it. The fines are stiff for them so I whipped it and all the wiring out pronto.
Land Rover Christchurch has had the police turn up and inspect / dismantle cars while they are being serviced on cars they suspect to have jammers installed.
https://www.driving.co.uk/news/jail-range-...le-finger/
Post #609187 14th Oct 2021 6:13pm
Rog21
dont thinks its that as it looks like it was designed to be there as its built into console. L322 4,4 TDV8
Freelander 2 sold
Honda Transalp
Post #609188 14th Oct 2021 6:23pm
mjdronfield
Have you got a pic?
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #609191 14th Oct 2021 6:31pm
Rog21
Pic of switch in middle. L322 4,4 TDV8
Freelander 2 sold
Honda Transalp
Post #609237 15th Oct 2021 8:12am
Rog21
Freelander 2 sold
Honda Transalp
Post #609238 15th Oct 2021 8:13am
Rog21
 L322 4,4 TDV8
Freelander 2 sold
Honda Transalp
Post #609239 15th Oct 2021 8:15am
could be anything....try following the wiring.. ... - .- -.
Post #609241 15th Oct 2021 8:25am
mjdronfield
That’s not factory fitted, but looks tidy. As Stan says, need to follow the wires.
Interesting to hear where it goes.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #609247 15th Oct 2021 8:57am
Rog21
Looks like it joins harness and goes forward into dash. Not sure I want to take that apart to have a look
 L322 4,4 TDV8
Freelander 2 sold
Honda Transalp
Post #609264 15th Oct 2021 11:49am
mjdronfield
The side panels near the climate controls pop off easy enough, so you can see the front of the centre console, but as you say, bit of a big job to go further….
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #609267 15th Oct 2021 12:18pm
Rog21
Solved
The switch cuts out the radio and connects an IPOD cable in the console to the Entertainment system. This does explain why sometimes my car used to start the radio and then go quiet, you had to then select the other radio input to get the radio working, the switch was obviously on when this happened.
I assume the standard fit is a USB and IPOD socket in centre console, mine also has an IPOD cable thats wired into the car that is underneath the other sockets. I had assumed that was a standard fit but obviously not. Not sure why you would want this, I haven't got the original IPOD cable so can't check if the IPOD socket works.
The only reason I can think of why you would want to do this is to connect an IPOD at the same time as an IPhone?
Anyway I think I will leave as is and only remove if the hifi plays up.
Roger L322 4,4 TDV8
Freelander 2 sold
Honda Transalp
Post #609472 17th Oct 2021 10:49am
mjdronfield
That sounds like a good plan. Least you know.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #609478 17th Oct 2021 11:53am
