![]() | Home > Technical (L322) > 4.4 tdv8 won’t start (not battery) |
coopss Member Since: 21 Apr 2018 Location: Hampshire Posts: 281 ![]() |
Cheers! Not actually cleaned them yet. Tempted to take off the mud flaps as I think they spoil the lines, particularly at the back. Also make the wheels look quite far in 1995 4.6 v8, green/tan (long gone) 2005 4.8iS X5, blue/black 2011 4.4 tdv8, black/black (gone) 2003 3.0d X5, Oxford green/black/manual 2021 p575 SVR, BR green/vintage tan |
ffrr14 Member Since: 21 Apr 2021 Location: Sydney Posts: 187 ![]() ![]() ![]() |
Blue wire is for the BMS, it is very important for the charging system. How is the charging anyways? SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC New Toy: Unimog U1550L/37 New : G350D |
Very interesting. When running I get 14.7 volts via IID. Howeve when I turn it off, I get a low battery message within 5 mins with 12-12.7 volts showing on the IID. This is the second battery 1995 4.6 v8, green/tan (long gone)
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2617 ![]() ![]() |
The low battery warning is an irritation you can largely ignore if you know the battery is good and it’s charging properly. |
