Home > Maintenance & Mods (L322) > KRB500180 engine under tray fasteners
JayGee
Just ordered the tray as it was missing but not sure what kind of fasteners I need to attach it? 2012 TDV8 Vogue (L322)
Post #608977 12th Oct 2021 8:42pm
Merchy
If it is anything like mine, ( 2006 ) what you need are spire nuts and self tapping type screws.
If you are not sure what I mean, the link below shows the spire nut design, ( as an example )lot's of sizes, plentiful and cheap to buy. Stainless steel ones are best, especially for the under side of a car.
https://www.googleadservices.com/pagead/ac...amp;adurl=
Post #608989 12th Oct 2021 11:59pm
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
Apologies for resurecting this old thread, but did you ever find what the part number was for the under tray fasteners ?
Mine are spire screws, 10mm hex head, 23mm thread length, 6mm outer diameter.
The only ones I've found are all too short, I'd rather have the real thing before trying to find an alternative.
Andy Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #694946 23rd Jun 2024 1:15pm
Rusty Nuts
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Buckingham Blue
Hi Andy,
If it helps I bought this kit and they work superbly-
https://www.ebay.co.uk/itm/131818110346?mk...media=COPY
Post #694964 23rd Jun 2024 9:38pm
AndyRoo
Thanks Rusty Nuts, I never thought about replacing the spring nuts as well. Many Thanks
Post #694975 24th Jun 2024 7:06am
Rusty Nuts
No problem- replace the whole set to nice stainless ones. Makes a neat job of it.
Andrew.
Post #694977 24th Jun 2024 7:39am
steve k
United Kingdom 2003 Range Rover HSE Td6 Giverny Green
I use these, not stainless but pretty much exact copy of originals:
https://www.diycarserviceparts.co.uk/metal...36616.html
They also do the 8mm type used in areas such as wheel arch liners. Grease them fully and they should be fine for a few years. Both types incorporate a retained washer as per original. Current: 2003 TD6 HSE. 161,000 miles
Previous 1993 Classic 3.9
Post #695045 25th Jun 2024 8:21am
AndyRoo
Thanks, I've gone for the stainless ones as on close inspection the spring clips are corred badly so replace the lot I think in one go.
Cheers, Andy Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #695104 26th Jun 2024 3:53pm
Rusty Nuts
Good choice !
Andrew.
Post #695108 26th Jun 2024 5:33pm
