Home > Technical (L322) > Help! Passenger side deployable side step stuck
G3BML
Scotland 2010 Range Rover Vogue SE TDV8 Santorini Black
Hi people, recently purchased a lovely 2010 4.4 tdv8 with factory fitted deployable side steps. Today when I unlocked the car, both steps came out as normal. I jumped in the car and before I started the engine , I could hear a grinding like noise from the passenger side. Jumped out and found the passenger side step stuck half out.
Opening and closing the doors I can hear the motor but no movement. Tried giving it a bang and push/pull but no luck
Anyone had a similar experience or know where to go from here? Am I looking at a L/H motor?
Thanks
Post #607125 23rd Sep 2021 1:47pm
cass
Most likely the pivots on the brackets stiff/siezed
Post #607131 23rd Sep 2021 3:56pm
G3BML
Assume I’d need to remove the brackets and try freeing them off?
Still have my suspicions about the motor though, found this when lying underneath. Looks like the casing on the motor has rotted and the bolts have snapped. Don’t know if it’s worth the bother seeing if it’s repairable or just biting the bullet for a new one…
Post #607150 23rd Sep 2021 7:12pm
G3BML
Update : ordered a new left hand motor from Maltings. £330 Confused arrives Tuesday so will update once I’ve fitted it!
Post #607330 25th Sep 2021 10:01pm
G3BML
Fitted new step motor today. Old one had badly seized onto the hinge/bracket, to the point I had to apply heat and gentle persuasion with a hammer. I cleaned both brackets up before fitted new motor and noticed two hairline cracks on the pivoting part of the bracket. Thinking it would be fine, I fitted the new motor and reassembled everything back onto the car. Step now working… for two minutes then the hinge gave way. Now had at order a new front hinge from Maltings at the eye water cost of £225. Ouch Shocked Laughing guessing this car will keep me busy and my wallet empty ha
Post #607940 2nd Oct 2021 3:18pm
G3BML
Got the new bracket delivered and fitted today. Took 30 mins seeing as I have had it off just last week haha. Finally have a working deployable step.
Here is the new one installed
And here is the old one. You can see where it has cracked. Does anyone know if it’s repairable or scrap?
Post #608490 6th Oct 2021 4:44pm
dhallworth
It’s more then likely scrap unless you can find someone to weld it for you.
When you need parts like that, give Rob at Duckworths a shout as he can usually get forum members a bit of discount on parts.
2007 Range Rover Supercharged in Java Black with Ivory Leather
Post #608518 6th Oct 2021 7:39pm
G3BML
Thanks for the heads up David, will give them a shout in the future. Only had the car two days when the step failed. Fingers cross nothing else unexpected pops up and I can actually get round to sorting the other things that need doing.
Lewis
Post #608531 6th Oct 2021 9:58pm
muddycharles
United States 2008 Range Rover HSE 4.4 V8 Bonatti Grey
Do you have a part number - I need to do the same thing?
HI
Any chance you can provide a part number?
Thanks
Alex 2008 HSE B. Grey
Overfinched
NavTV retrofit
Post #608665 8th Oct 2021 8:47pm
G3BML
Motor - LR004807
Bracket - LR004809
Post #608668 8th Oct 2021 10:00pm
muddycharles
Excellent
Thank you !!!!!
To be 100% sure - this is for the passenger side right? 2008 HSE B. Grey
Overfinched
NavTV retrofit
Post #608854 11th Oct 2021 3:05pm
RRV8SC
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Santorini Black
Crikey, that's a mess. Not the repair, the old bit.
Is it worth wax oiling the motor casing, or is this a one off?
Cheers
Post #608916 12th Oct 2021 8:24am
G3BML
Re: Excellent
muddycharles wrote:
Thank you !!!!!
Just seen your in America, part numbers I have listed are for passenger side ( left side ) in the UK.
Right hand side part numbers would be,
Motor : lr004808
Front Bracket : lr004810
Post #608919 12th Oct 2021 9:14am
G3BML
Cheers
Not sure, maybe a one off but going to make sure to give them a dose of ACF50 and lube the pivot points with Wurth HHS2000 every couple of months just to be sure.
Post #608922 12th Oct 2021 9:20am
