![]() | Home > Technical (L322) > Help! Passenger side deployable side step stuck |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 756 ![]() ![]() |
Most likely the pivots on the brackets stiff/siezed |
G3BML Member Since: 22 Jul 2021 Location: Glasgow Posts: 98 ![]() ![]() ![]() |
Assume I’d need to remove the brackets and try freeing them off?
Update : ordered a new left hand motor from Maltings. £330 |
Fitted new step motor today. Old one had badly seized onto the hinge/bracket, to the point I had to apply heat and gentle persuasion with a hammer. I cleaned both brackets up before fitted new motor and noticed two hairline cracks on the pivoting part of the bracket. Thinking it would be fine, I fitted the new motor and reassembled everything back onto the car. Step now working… for two minutes then the hinge gave way. Now had at order a new front hinge from Maltings at the eye water cost of £225. Ouch |
Got the new bracket delivered and fitted today. Took 30 mins seeing as I have had it off just last week haha. Finally have a working deployable step.
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3201 ![]() ![]() ![]() |
It’s more then likely scrap unless you can find someone to weld it for you.
Thanks for the heads up David, will give them a shout in the future. Only had the car two days when the step failed. Fingers cross nothing else unexpected pops up and I can actually get round to sorting the other things that need doing.
muddycharles Member Since: 05 May 2011 Location: Miami, FL Posts: 90 ![]() ![]() ![]() |
HI
Motor - LR004807
Thank you !!!!!
RRV8SC Member Since: 02 Oct 2021 Location: SW London Posts: 185 ![]() ![]() ![]() |
Crikey, that's a mess. Not the repair, the old bit.
Just seen your in America, part numbers I have listed are for passenger side ( left side ) in the UK. Right hand side part numbers would be, Motor : lr004808 Front Bracket : lr004810 |
Not sure, maybe a one off but going to make sure to give them a dose of ACF50 and lube the pivot points with Wurth HHS2000 every couple of months just to be sure. |
