![]() | Home > Technical (L405) > L405 Randomly stuck in Park |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35602 ![]() ![]() |
sounds similar to this problem,
GB78 Member Since: 03 Dec 2019 Location: Essex Posts: 70 ![]() ![]() ![]() |
I had a similar problem earlier this year, selector wouldn't move occasionally after start up. It then decided to fail properly when reverse was selected and wouldn't move back. Had to have a new Rotary selector solenoid installed. Mine probably caused intermittent problems for approx 2-3 weeks before kaput. |
njmacleod Member Since: 26 Mar 2018 Location: Edinburgh Posts: 7 ![]() ![]() |
Thanks GB78 - was it a big job to replace? Thinking it might be safer to replace before it packs up... |
From what I know, the centre console was stripped out to gain access to the module itself. The part for mine was £680 I think (vin dependant apparently)
Hammer Member Since: 14 Oct 2012 Location: Perth Posts: 123 ![]() ![]() ![]() |
Just replaced mine over the weekend, purchased from island 4 x 4. Had to remove the Centre console cover, taking my time the job took six hours. Online there’s a video on how to remove the 2019 L405 console but it is slightly different to my 2015 main difference was 2015 has 2 screws plus clipped down and arm rest has a long pin. 2019 6 screws plus armrest screwed down.
Mine never made an audible noise whenever it was having a hiccup, just locked rigid.
Took my time on a lazy Sunday, you could do it a lot faster. 2015 AB 5.0 Supercharged
Thanks for the replies.. the update is - I parked up this morning and heard a 'double click' now the gear selector won't move for love or money but interestingly I don't hear anything when the footbrake is applied - I had the pads and discs replaced a month ago, just wondering if its related? I will let it have a rest overnight and try again but I am not holding out much hope.
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 773 ![]() ![]() ![]() |
Give Gentlemen Of Salvage a call. I have used them previously. Very helpful.
You may also find the below guide useful...
Final Update... the RR got towed away at lunchtime today and dropped off at Andy Whites. Andy did his magic and the car was ready for 4pm same day. Cant fault that, sadly though I am now an owner of an expensive paperweight aka a broken rotary gear selector |
