Home > Technical (L405) > L405 Randomly stuck in Park
njmacleod
Hello – looking for some help please
Just recently the gear selector started to randomly get stuck in park, the gear selector raises from the centre console as normal but wont allow me to select R N or D… we don’t get the ‘click’ when you press down on the foot brake. We don’t get this problem all the time it seems random, sometimes when the car is cold other times when the car is warm.
To correct the problem, we sometimes switch the car off/on but this doesn’t always fix the problem, other times it seems to ‘release’ from P after the foot brake has been pressed a few times or in most cases it seems to resolve its self and allows us to select R N or D. The stuck in Park doesn’t last more than 2-3 mins at worst and in most cases it fine within a minute or so.
I am concerned the problem might develop further and we are left stuck in park – any suggestions or help?
2014 Range Rover
80K on the clock
Serviced every year, last service was in August
Thanks in advance
Post #607735 29th Sep 2021 9:50pm
sounds similar to this problem,
https://www.fullfatrr.com/forum/topic60860.html ... - .- -.
Post #607737 29th Sep 2021 9:54pm
GB78
England 2014 Range Rover Vogue SE TDV6 Santorini Black
I had a similar problem earlier this year, selector wouldn't move occasionally after start up. It then decided to fail properly when reverse was selected and wouldn't move back. Had to have a new Rotary selector solenoid installed. Mine probably caused intermittent problems for approx 2-3 weeks before kaput.
Post #607794 30th Sep 2021 3:42pm
njmacleod
Thanks GB78 - was it a big job to replace? Thinking it might be safer to replace before it packs up...
Post #607797 30th Sep 2021 4:30pm
GB78
From what I know, the centre console was stripped out to gain access to the module itself. The part for mine was £680 I think (vin dependant apparently)
So once you factor in labour, it’s not a cheap fix.
Might be worth getting it plugged in before you make any decisions, you might be lucky and find a code pointing at a dodgy brake switch or something.
Post #607815 30th Sep 2021 9:33pm
Hammer
Australia 2007 Range Rover Vogue TDV8 Zambezi Silver
Just replaced mine over the weekend, purchased from island 4 x 4. Had to remove the Centre console cover, taking my time the job took six hours. Online there’s a video on how to remove the 2019 L405 console but it is slightly different to my 2015 main difference was 2015 has 2 screws plus clipped down and arm rest has a long pin. 2019 6 screws plus armrest screwed down.
If I was to do it again I reckon I can do in two hours.
Apparently there’s also an update for software that helps fix this issue. However I didn’t wanna mess around and be caught somewhere I have to leave the car. So I just replaced it.
When it was faulty, I could hear a solenoid trying to activate in the rotator unit every time I press the brake pedal but it would not release, it worked after day or two later however wasn’t willing to take the risk going forward. 2015 AB 5.0 Supercharged
2007 TDV8 Vogue
2000 P38, Gen3s, 2 inch lift, KM2s 285/75/16
Post #607857 1st Oct 2021 1:17pm
GB78
Mine never made an audible noise whenever it was having a hiccup, just locked rigid.
Doesn't sound like a fun job (6hrs) Shocked
Post #607860 1st Oct 2021 1:58pm
Hammer
Took my time on a lazy Sunday, you could do it a lot faster. 2015 AB 5.0 Supercharged
2007 TDV8 Vogue
Post #607862 1st Oct 2021 2:18pm
njmacleod
Thanks for the replies.. the update is - I parked up this morning and heard a 'double click' now the gear selector won't move for love or money but interestingly I don't hear anything when the footbrake is applied - I had the pads and discs replaced a month ago, just wondering if its related? I will let it have a rest overnight and try again but I am not holding out much hope.
My local indie garage, Andy Whites said failures on the L405 are rare compared with Evoques - anyway we'll see what tomorrow brings then arrange a lift and shift to Whites.
Couple of questions - anyone tried repairing the gear selector or is it unserviceable?
Also, a quick google showed perhaps buying a gear selector from a breakers might do the job? Anyone know any good breakers breaking L405s at the moment?
Thanks again for all your input - I have followed this forum for years but never had to post
Post #607958 2nd Oct 2021 6:25pm
knwatkins
Give Gentlemen Of Salvage a call. I have used them previously. Very helpful.
https://www.gentlemenofsalvage.co.uk/ Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #607970 2nd Oct 2021 7:56pm
knwatkins
You may also find the below guide useful...
https://www.aulro.com/afvb/l319-discovery-...blems.html Kev
Post #607973 2nd Oct 2021 8:07pm
njmacleod
Final Update... the RR got towed away at lunchtime today and dropped off at Andy Whites. Andy did his magic and the car was ready for 4pm same day. Cant fault that, sadly though I am now an owner of an expensive paperweight aka a broken rotary gear selector Laughing
Thank you all for your help, fingers crossed now more dramas
Post #608354 5th Oct 2021 4:49pm
