Home > Technical (L322) > Are the any differences in front suspension struts? |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1188 |
Check out Robin at Duckworth's we get 20% off parts for the right parts? |
28th Sep 2021 7:59am |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1340 |
I would imagine that you can do as you suggest, just remove the threaded collar and swap to the new strut. They can be a bit of a job to remove though and the monkey that swapped mine never got it put on tight enough before adding the damper weight to the top
28th Sep 2021 9:18am |
Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 688 |
Pre & post 2006 facelift are different and petrol, diesel and Supercharged. Paul,
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3233 |
My FF is also a 2008 Tdv8. I have just had both of mine done by a local chap. The front right was done first. It was necessary to remove the vibration damper from the old strut. It had to be done once removed as there is no way to hold it in situ. I detailed it on here https://www.fullfatrr.com/forum/topic60828.html
28th Sep 2021 9:20am |
Tiprat Member Since: 05 Aug 2021 Location: Manchester Posts: 92 |
As always guys, thank you for all your inputs it helps me make an educated decision, and it's good to hear others who have experienced this.
28th Sep 2021 11:14am |
