Home > For Sale & Wanted > [sold] 2007 Range Rover Vogue SE now sold
Sean
England 2007 Range Rover Vogue SE TDV8 Java Black
Due to lack of use (2k per year for the last two years) I am putting up the 2007 Vogue SE for sale.
Its java black with a Westphalia towbar.
I purchased it nearly two years ago from a forum member and it now has 104k on it.
The previous advert on this forum advert can be seen here
https://www.fullfatrr.com/forum/topic53670.html
hope thats okay Tom.
I will put some photos on tomorrow but its not changed with 2 more subsequent services. The reg stayed with the previous owner therefore the reg is different now. Its got 12 months MOT. Some advisories but nothing significant. It comes with full service history and is a lovely car.
It has an issue. It occasionally goes into limp mode but clears on turning the engine off and re starting. I have had the codes read and its saying map sensor A. The sensor has been cleaned and swapped with sensor B. Price is 6.7 k to reflect this.
Some more photos will be posted tomorrow.
Donation to site if sold on here.
There’s a spare set of alloys to go with it with winter tyres on. Two with decent tread two with less so.
I am based near Penrith
Ok I have now had the issue sorted it was a split pipe. Diagnosed with a smoke machine and replaced
Some pics below to add to Tom’s in the link. Everything works as it should be and it really is a good example.
I am adjusting the price to cover the cost of getting it sorted so it’s now 6900
Post #607396 26th Sep 2021 1:00pm
quavey
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
With it going into limp, does this happen at first startup? Or when driving etc? Is there any particular circumstances that cause it to go into limp? I'm wanting a slightly newer one than my 2004 and from the images last time this looked nice. 2005 E60 M5
2006 (MY07) L322 4.2 S/C
2024 i7 xDrive60
2004 L322 4.4 Vogue, 2002 L322 4.4 HSE, 2006 (MY07) L322 S/C , 2001 P38 Vogue, 1999 P38 4.6 HSE.
Post #607508 27th Sep 2021 2:23pm
Sean
It mainly does it when your going up a slight hill and ease off at the top. Typically when it’s cold. I looked at the hoses at the top and they seem fine. It will then run for miles with no issues. Looking at people with a similar issue on here it ended up being a crack in one of the inlet manifolds so I guess that’s the worst case scenario. I may get a smoke test on it next week.
Post #607510 27th Sep 2021 2:43pm
quavey
Thanks for the info, I'd be interested to know the results of a smoke test. I expect inlet manifold replacement is far beyond my capabilities. 2005 E60 M5
2024 i7 xDrive60
Post #607535 27th Sep 2021 8:37pm
L19 MUD
United Kingdom 2009 Range Rover Vogue SE TDV8 Stornoway Grey
Have a read up on how to change the EGR's as the inlet manifold needs to come off to do them. It really is not hard to remove
Post #607565 28th Sep 2021 10:35am
Sean
Thanks L19
Will look at that. I think a new one is around 500-600. But would need to check
Post #607574 28th Sep 2021 11:53am
L19 MUD
Personally I have not come across a cracked inlet manifold yet on the 3.6 (but other people certainly have) but I have seen loads and loads of split intercooler hoses, they always seem to go at the back so you cannot see them too so taking them off and then bending them about is the only way to find the split normally.
Once found some duct tape wrapped round is normally enough to get you by until replacements turn up
Post #607576 28th Sep 2021 12:01pm
I've got one on my 3.6 Got - 2017 SDV8 Autobiography in Loire Blue
Post #607610 28th Sep 2021 5:45pm
Sean
Thanks guys. I am booking it for a smoke test next week. So will see, will check over the hoses as well this weekend.
Post #607740 29th Sep 2021 10:46pm
latent
Hey any news on results from the smoke test?
Post #608551 7th Oct 2021 12:01pm
Sean
See above issue now sorted. It was a split hose and now runs as it should do.
I have changed the price to 6900 to reflect the issue has now gone
Post #608708 9th Oct 2021 10:50am
spbee
so glad for you it wasn't the manifolds
Post #608717 9th Oct 2021 12:54pm
Sean
Me too. To be fair it’s a lovely car and now runs so well.
Post #608720 9th Oct 2021 1:13pm
Andy79
Hi Sean.
Is this still for sale ?
Thanks,
Andy
Post #608910 12th Oct 2021 7:34am
Sean
Yes it is. It’s a very reluctant sale but yes it is
Post #608915 12th Oct 2021 8:58am
