Home > Maintenance & Mods (L322) > Loud knocking noise only when driving over speed bumps
jaysta10k
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
Hi guys any help would be appreciated got this really annoying knocking noise only present when going over speed bumps or uneven surface.
Cheers
Jay Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Audi A4 2.7 TDI S Line Black Edition phantomn black
Previous Cars
Range Rover Vogue SE Overfinch Styling 22" Elara's full black stealth colour coded
Java black Range Rover sport 2.7 TDV6
Alaska white Range Rover sport overfinch 3.6 TDV8
BMW M3 Carbon Black
Post #606082 10th Sep 2021 10:54am
bishbosh10
These fatties are renowned for eating suspension bushes. I would start there first. Bish.
2005 110 TD5 CSW
2011 TDV8 Vogue SE (gone)
Post #606086 10th Sep 2021 11:49am
Worn anti roll bar drop link.
Post #606088 10th Sep 2021 12:28pm
Merchy
Best way to find out which suspension parts are worn / loose - Find an MOT station with a shaker plate, bung them a few quid to get underneath it and have a look, they will probably find the reason fairly quickly.
If the noise can be definitely confirmed to be at the front or rear, tell the mechanic this to help him zero in on the fault. The above drop links could well be the cause.
Post #606098 10th Sep 2021 3:26pm
Dolphinboy
what's a shaker plate?
Post #606110 10th Sep 2021 5:51pm
Bean19844
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Driver the car onto a plate and it rocks the car side to side so the tester can check for any excess movement on bushes, suspension etc
Post #606117 10th Sep 2021 7:32pm
Merchy
If no shaker plate is available Shocked then a good MOT tester will be able to use lever bars to find the wonky part, won't take him long.
Post #606130 10th Sep 2021 8:43pm
jaysta10k
Cheers guys it was the front passenger side anti roll bar drop link do I need to buy the drop link on its own or with bushes.They only come in a set left and right and with or without bushes. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Previous Cars
BMW M3 Carbon Black
Post #606399 14th Sep 2021 8:59am
Merchy
If one drop link has worn, the other will not be far behind, changing both is best, bars always come with bushes as far as I know. While you are at it, try to move the anti roll bar, if there is any movement by hand, then you probably need those bushes as well.
Post #606400 14th Sep 2021 9:17am
Danwilderspin
just did my struts noises are gone now Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #606763 18th Sep 2021 10:02pm
