![]() | Home > Maintenance & Mods (L322) > Loud knocking noise only when driving over speed bumps |
bishbosh10 Member Since: 25 Apr 2013 Location: North Somerset Posts: 344 ![]() ![]() |
These fatties are renowned for eating suspension bushes. I would start there first. Bish.
Worn anti roll bar drop link. |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1223 ![]() ![]() ![]() |
Best way to find out which suspension parts are worn / loose - Find an MOT station with a shaker plate, bung them a few quid to get underneath it and have a look, they will probably find the reason fairly quickly.
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3199 ![]() ![]() |
what's a shaker plate? |
Bean19844 Member Since: 25 Oct 2020 Location: Essex Posts: 929 ![]() ![]() ![]() |
Driver the car onto a plate and it rocks the car side to side so the tester can check for any excess movement on bushes, suspension etc |
If no shaker plate is available |
jaysta10k Member Since: 24 Aug 2017 Location: Cheshire Posts: 299 ![]() ![]() ![]() |
Cheers guys it was the front passenger side anti roll bar drop link do I need to buy the drop link on its own or with bushes.They only come in a set left and right and with or without bushes. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
If one drop link has worn, the other will not be far behind, changing both is best, bars always come with bushes as far as I know. While you are at it, try to move the anti roll bar, if there is any movement by hand, then you probably need those bushes as well. |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2218 ![]() ![]() ![]() |
just did my struts noises are gone now Current stable:
