Home > Maintenance & Mods (L322) > Loud knocking noise only when driving over speed bumps |
bishbosh10 Member Since: 25 Apr 2013 Location: North Somerset Posts: 344 |
These fatties are renowned for eating suspension bushes. I would start there first. Bish.
10th Sep 2021 11:49am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3978 |
Worn anti roll bar drop link. |
10th Sep 2021 12:28pm |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1194 |
Best way to find out which suspension parts are worn / loose - Find an MOT station with a shaker plate, bung them a few quid to get underneath it and have a look, they will probably find the reason fairly quickly.
10th Sep 2021 3:26pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3167 |
what's a shaker plate? |
10th Sep 2021 5:51pm |
Bean19844 Member Since: 25 Oct 2020 Location: Essex Posts: 929 |
Driver the car onto a plate and it rocks the car side to side so the tester can check for any excess movement on bushes, suspension etc |
10th Sep 2021 7:32pm |
If no shaker plate is available then a good MOT tester will be able to use lever bars to find the wonky part, won't take him long. |
10th Sep 2021 8:43pm |
jaysta10k Member Since: 24 Aug 2017 Location: Cheshire Posts: 295 |
Cheers guys it was the front passenger side anti roll bar drop link do I need to buy the drop link on its own or with bushes.They only come in a set left and right and with or without bushes. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
14th Sep 2021 8:59am |
If one drop link has worn, the other will not be far behind, changing both is best, bars always come with bushes as far as I know. While you are at it, try to move the anti roll bar, if there is any movement by hand, then you probably need those bushes as well. |
14th Sep 2021 9:17am |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2215 |
just did my struts noises are gone now Current stable:
18th Sep 2021 10:02pm |
