Home > Technical (L322) > IIDTool from gap diagnostics ***Q & A *** |
Billy'sLad Member Since: 02 Jul 2021 Location: Southport Posts: 8 |
I have now had the opportunity to read a little of the manual and correspond with GAP engineer, who advised on procedure. Unfortunately car remains in Transportation mode. I follow the service/test procedure for both the bcu and the suspension Transportation mode disengage sequence, and they both report that the system is now active, but as soon as I hit continue, and the gap tool reads faults again the car is still in the same state. A little frustrationg to say the least, but she still drives fine so all is not lost. I have booked her in to Worldwide LR later this month to see what they can do. I would love to know if anyone else has ever had issues with Transportation Mode. Cheers |
1st Aug 2021 7:36pm |
jonnyboy54321 Member Since: 29 Jan 2016 Location: surrey Posts: 380 |
Hi all, odd situation here.
5th Sep 2021 11:59am |
Landphil Member Since: 03 Oct 2016 Location: U.K. Posts: 119 |
The IID tool is locked to the VIN of your vehicle not your phone. Your phone is simply the portal through which you see the tool. Get your friend to download the GAP App and he should be able to find the tool on his phone and use it on your vehicle. |
5th Sep 2021 12:29pm |
PS. You may need to give him the code to enter into his phone |
5th Sep 2021 12:33pm |
Chaz Member Since: 06 Oct 2020 Location: Oxfordshire Posts: 9 |
Hi, can this software code new replacement modules (for example, replacement ABS unit on my BMW originated 4.4 V8 2003/4? |
13th Sep 2021 1:09pm |
RoamingRange Member Since: 28 Jun 2015 Location: Cheshire Posts: 7 |
Does anyone know of there’s an option to reset the software for the FBH? Think I have a battery drain and there’s been a suggestion it can be the FBH software that is corrupted. Can’t find an option on the IID. |
17th Sep 2021 10:21am |
Johnniehec Member Since: 03 Feb 2017 Location: A a Posts: 23 |
Hi is it possible to see the odometer mileage reading via the GAP tool as my display is pixelated? Thank you, John. |
27th Sep 2021 4:07pm |
Caesium Member Since: 21 Sep 2021 Location: Essex Posts: 451 |
I had this with my iPad, until I rotated it into portrait mode. Seems in landscape mode loads of options are missing. |
27th Sep 2021 5:49pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3772 |
Johnniehec.
27th Sep 2021 7:29pm |
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 565 |
Looking to purchase a new iid as it appears to cover nearly everything.
28th Sep 2021 7:10pm |
Ramblin Man Member Since: 05 Apr 2022 Location: Southsea Posts: 276 |
My suspension is riding skewed so I worked through the guided height calibration procedure today.
5th Nov 2022 7:17pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3232 |
The guided adjustment is more problematic IME than the guides suggest. Yes the compressor can overheat and stop further adjustment, the doors need to be closed, the final values need to be updated by changing the ride height and then going into the custom height setting where it will ask for the values to be updated. Also you have to be very precise about measurements and I made a jig that plugs into the hub. If you have a faulty height sensor you will not get a good or any calibration. It's also possible worn inner bushes at the front on the arm where the sensor attaches can mess up the calibration as movement in dynamic situations may cause a height reading to change when it hasn't. Lastly (or perhaps this should have been firstly) if your car is riding skewed it's very unlikely it's a calibration error and almost certainly a component failure - air spring or height sensor. 2012 TDV8 Vogue (L322) |
5th Nov 2022 7:33pm |
Thanks @JayGee Yes I agree about the precision; I made a jig as well, I used an old wheel centre cap with some pre-marked cord through a hole in the centre. It worked okay. I rewatched the YouTube by Sam on this and can see what you mean by changing the ride height setting. Unfortunately I never get that far in the guided procedure due to the E17 error. I might give it another go later on today. Here’s the link to YouTube for the benefit of anyone else trying this https://youtu.be/9ot3L4CHPd4 TDV8 4.4 2012 |
5th Nov 2022 8:10pm |
First check I would do is to compare the height calibrated with actual values in the GAP tool vs the hub heights. 2012 TDV8 Vogue (L322) |
6th Nov 2022 10:18am |
