![]() | Home > Technical (L322) > Removing CVD dampers and replacing for standard |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 ![]() ![]() ![]() |
This is a frustrating read… I feel the harsher ride in my current than I did in my last L322 which also was a 2010 model with CVD, but put it down to running 22’s with 35 sidewalls. I plan to change to larger sidewalls when they are in need of replacement but worry it’ll be of limited benefit
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1200 ![]() ![]() ![]() |
This is a question for Graemes do you know if Old Emu does a CVD damper or would you say that OEM is up to the job when towing a heavy Tintent? I know Blistins have a good name but Old Emu have done a lot of work in Australia and a lot of bush whackers use them? |
At this point it may be worthwhile someone explaining exactly what the CVD system is supposed to do?
coopss Member Since: 21 Apr 2018 Location: Hampshire Posts: 281 ![]() |
It varies the oil flow in the dampers based on surface conditions (also monitors pitch/roll and tries to compensate for it). Tyres shouldn’t affect it. What I found that did affect it was a bent, unbalanced wheel. It tries to compensate for wheel tramp (wheel bouncing) by firming the damper - a bent/unbalanced wheel must give the ecu similar characteristics 1995 4.6 v8, green/tan (long gone)
Logically with faster inputs from an unbalanced wheel the damping should ease off. |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2558 ![]() ![]() ![]() |
Ensure that your CVD software is at the latest level. The L322 was LRs first use of CVDs so lessons learnt since their introduction including lessons learnt from the L405 and L494 could have triggered software updates for early vehicles.
The bypass valve is regulated taking into account whether the shock is compressing or extending, not just considering shock shaft speed. I have or used to have a LR technical document on their CVD operation but can't currently find it. |
Well I’ve had one of the front dampers replaced. I’d noticed that the front right of the bonnet was bouncing when comparing it to the road ahead. Found the left was replaced a couple years ago with a BWI unit so used the same for the front right.
Well that’s reassuring!!!
Yep harsh very bouncy ride. Turning off traction control now replicated the issue (disables the cvd system) whereas before it made no change 1995 4.6 v8, green/tan (long gone)
Interesting mate - can this be done safely with a GAP tool? 1995 4.6 v8, green/tan (long gone) 2005 4.8iS X5, blue/black 2011 4.4 tdv8, black/black (gone) 2003 3.0d X5, Oxford green/black/manual 2021 p575 SVR, BR green/vintage tan |
On my Audi with air suspension and user selectable damper rates I have recently found that at the softest setting the ride is harsh and crashy at slower speeds over urban roads with potholes and speed bumps etc but very smooth at higher speeds on A and B roads. Conversely at the stiff setting it's more comfortable and non crashy at lower speeds but quite harsh at higher speeds. This would suggest that worn shocks = crashy ride at low speeds which is very counter intuitive but seems to be confirmed by experiences here. |
Yeah I think the solenoid gave up with meant it was on the hardest setting permanently. Couple that with 155k miles on them and it resulted in a terrible ride 1995 4.6 v8, green/tan (long gone)
With most cars once you get up to around 100k miles or even before the shock absorbers will be well past their best and should be replaced as a 'service item' for best performance. An expensive exercise for the facelift models and hence why I'm looking at pre facelift 3.6's or high mile 4.4's where this has already been done. |
