Home > My Range Rover > Back with another Supercharged
Page 16 of 58 <123 ... 151617 ... 565758>
CongoBoy
South Africa 2005 Range Rover Vogue SE 4.2 SC V8 Java Black
dhallworth wrote:
I’ve had the Range Rover for a run this afternoon and am pleased to report the whine has gone and the car is changing gear beautifully. There’s still a feint grumble from the front diff but it’s not bad so it can wait for a while. The oil I put in it in January is still clean so it can’t be doing much damage to itself and Cheryl can hardly hear it so it’s probably just me being OTT.
Anyway, long story short, I have a working Range Rover again Very Happy
David.
Brilliant!! I'm happy for you! Thumbs Up
A very informative thread!! 2005 FFRR SC Java Black with Overfinch Exhaust (UK)
2008 D3 HSE Stornoway Grey (UK)
2008 D3 HSE Izmir Blue (ZA/Zimbabwe)
1995 D1 300 Tdi (Zimbabwe)
Post #603153 7th Aug 2021 10:01pm
Well done David... Glad its all sorted sir... Thumbs Up
Post #603156 7th Aug 2021 11:17pm
Well done David. There is nothing that can't be fixed with a hammer😜😜
Post #603213 8th Aug 2021 4:20pm
dhallworth
We’ve done 50 miles in the RR this weekend and I’m pleased to report the new gearbox is as smooth as a hot knife through butter and the transmission is nice and quiet.
I’ve been looking in the workshop manual to see how you remove the front diff but I can’t find anything. Got a horrible feeling you need to drop the subframe which means it’s unlikely I’ll be able to do the job myself. Sad
Post #603239 8th Aug 2021 9:42pm
David,
IIRC you just have to undo the engine mounts and jack it up 40mm or so to clear the front subframe, diffs bolted to the sump with 4 bolts... Thumbs Up Pete
Post #603274 9th Aug 2021 12:45pm
Superspoons
Brilliant thread David - pleased you've got it sorted. Gavin
https://www.youtube.com/@ChallengingClassics
Post #603287 9th Aug 2021 3:08pm
dhallworth
Thanks guys Smile
It’s nice to have it running again anyway.
Post #603312 9th Aug 2021 7:02pm
dhallworth
I’ve been a bit slow updating this... It’s not that I’ve had 8 reliable days from the Range Rover 😂
After the heavy showers last week, well, more appropriately, monsoons! I noticed that the headlining in the Range Rover was wet and when coming to standstill water dripped onto the passengers seat from the B pillar. I decided to clear all the sunroof drains to hopefully cure the fault.
Fronts were easily done, sunvisors removed, grab handles removed and A pillar covers removed and I could just get my hand behind the headlining enough to reach the drain tubes. I pulled them off, attached the airline to them and blew 10 bar of pressure down them. After this, water flowed freely when I poured water from a jug into the sunroof tray.
The rears were a different story altogether. You cannot see the rear drain tubes from the top and from the rear they discharge water behind the wheel arch liners. I put the car on the ramp, removed the rear wheel arches and cleared the drains from the bottom up. Once I’d done that the water was flowing from the rears with no issues at all.
One thing that has always bugged me with this car was that when it switched to LPG the engine management light came on with a fault code for high fuel rail pressure. It also didn’t feel nice running on LPG either, it felt a bit strangled.
On older cars such as my P38 Range Rover there was a fuel pressure regulator on the fuel rail. This regulated the fuel pressure and the fuel returned to the tank using a separate pipe. On the newer cars there is no pressure regulator, the pressure is regulated by the in tank fuel pump. When the car switched to LPG and closed the petrol injectors the fuel pressure would spike as you can’t just disable the fuel pump. This would then trigger the car to run with the EML on and it felt horrible.
There are two ways around this problem…
1. Wire the fuel pump so that it shuts off and then use an emulator to emulate the fuel pressure and confuse the ECU into thinking things were fine.
2. Install a fuel pressure solenoid. These are powered when the car switches to LPG and will bleed fuel above a set pressure and need a return to be plumbed into the fuel tank.
I had never found either of these on this car so I’ve only ever run it on LPG for a few journeys.
When removing the wheel arch liner on the rear right wheel I found a fuel pressure solenoid hidden in the rear quarter. When I touched the solder joints on the cables they fell apart in my hands. I cut the wiring right back, cleaned up the installation a bit, replaced a couple of sections of wire and then soldered them back up before wrapping them in heat shrink.
Now, when the car switches to LPG the EML stays off and the running on LPG is equally as good as it is petrol. If I covered the switch, I defy anybody to tell me what fuel this car is running on.
I had to use the trailer the other day to help a friend out so for the first time since I’ve had this car it got put on towing duties.
I needed to move a Citroen BX for a friend of mine. The RR on LPG ran beautifully whilst towing, performance was superb, handling was superb, the suspension and steering on this car are absolutely spot on.
The only thing that’s irritating me is the diff whine. The front diff was noisy when I got it but the rear diff appears to have gotten noisy recently for some reason. An hour on eBay this evening found me a pair of diffs. They’re both New Old Stock from Land Rover.
The front diff from Land Rover is £1,057. This picture from the eBay advert isn’t great.
The rear diff from Land Rover is £2,539.
The dealer who had them offered me the pair of them for £1100 inc delivery on a pallet.
I’ve also been keeping an eye out on eBay for genuine LR wheel bearings recently too. I’ve now got 3 of them so have ordered a 4th tonight. Whilst the shafts are out to do the differential swaps I’m going to replace all 4 wheel bearings and be done with it. It’ll have had a full drive train refresh then and will hopefully be as quiet as a new car as other then these transmission whines I’m really enjoying driving it.
Interestingly, on the box for the LR wheel bearings they say “Made in Germany”.
The bearings themselves however are branded FAG.
And are made in Slovakia.
Anyway, that’s all until my pallet arrives and then I’ll have even more to be keeping me busy!
Post #604230 19th Aug 2021 10:41pm
Good bit of tinkering to get on with then….
I had my front bearings changed on my 07 and it was by all accounts a PITA….. I think the difficult part is actually getting the shaft out of the hub, but if you are having the diff off too then it might be a bit easier…. There is nothing that can't be fixed with a hammer😜😜
Post #604239 20th Aug 2021 6:35am
Bean19844
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Such a detailed and interesting reading article this one David. Enjoy reading this that's for sure
Post #604245 20th Aug 2021 7:47am
dhallworth
Thanks guys Smile
I'm fed up with whining noises on the drive train and when I got the offer of these diffs at that price it seemed to good a deal to turn down. My front one doesn't seem to have enjoyed towing the other day either and something can be felt under my feet since doing it.
I just want this car sorted out now. Seems like I'm forever doing something and the wife is now getting fed up with it so am hoping after this it'll just work for a while!
The joys of buying a 14 year old Range Rover Very Happy
Post #604253 20th Aug 2021 9:27am
Bean19844
And that's why I'm single mate. Don't have that worry of upsetting any females apart from those at work but any vehicle you buy that's pretty much older then 3 years is always gonna come with trouble
Post #604257 20th Aug 2021 9:56am
dhallworth
I'm very lucky tbh, she doesn't mind me tinkering with cars but this one has cost a fortune recently. I've also promised her a new kitchen which keeps sliding down the list due to the cars taking priority! Laughing
Post #604272 20th Aug 2021 11:49am
Merchy
Very interesting and informative thread Thumbs Up Bow down Bow down
That is a brilliant deal on the diff's Shocked I wish I was that lucky !!
As for the bearings, companies like FAG, SKF seem to have bearing factories ALL over the world now, quality is usually very good wherever they are made, except China obviously.
Hopefully, when you get around to the boss's new kitchen, that should be more reliable. Whistle Thumbs Up
At this rate your old fatty will soon be classed as new. Thumbs Up
Post #604278 20th Aug 2021 1:18pm
dhallworth
To be honest, I'm of the mindset now that I've come so far with it now I might as well make it perfect.
It's a car that cost me £2.5k in January. I've done a lot of work to it but none of what I've done would necessarily have been guaranteed not to be needed on one I'd paid £8k for.
I've spent a lot of time recently looking at 5.0 ones again, the way the used car market is just now, prices are high and again, I could have to do timing chains or a lot of work to one of them too so I've decided that I might as well keep this one for a while.
By the time I'm finished, this car will have had a brand new transfer box, brand new front and rear diffs, brand new rear driveshaft and 4 brand new wheel bearings so pretty much the entire drivetrain will be new so it'll hopefully give a few years of trouble free service!
Post #604280 20th Aug 2021 2:22pm
