![]() | Home > General > Checking on some specs pls. |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7865 ![]() ![]() ![]() |
You are right with the climate, mine just has a single knob for temperature in the rear, 4 zone has 2.
Just had a look, seems there were 3 headlining options. Not sure what the difference of the non leather ones then.
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3149 ![]() ![]() ![]() |
If you have deployable steps you really don't want them out all of the time. They hang quite low and would be susceptible to kerbs, etc. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
As above really, if the steps were left out and your car was in access mode! You could easily snap them off on high kerbs!!! |
karlak Member Since: 14 Jan 2021 Location: Bedfordshire Posts: 25 ![]() ![]() |
Thankyou for the replies.
Landphil Member Since: 03 Oct 2016 Location: U.K. Posts: 119 ![]() ![]() |
The side steps move in and out automatically when doors are opened or closed and on locking, unlocking.
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1200 ![]() ![]() ![]() |
The same button also will keep them turned off? |
As above… Yes they can be locked in or out sir 👍 |
Sorry to be a pain,, another check..
RSE was optional on all models in 2011. It was only standard on the Vogue SE up to 2009 IIRC.
All the specs for the 2011 cars are in the Wiki mate. I loaded a PDF up a month or so ago....
Yes, spotted that thanks,, very helpful..
They look original rear screens. After market ones usually have a different design.
Yes, that looks factory fit. Should have 6 DVD changer in the boot and rechargeable remote in the rear armrest... and 2 headphones....
