Home > General > Checking on some specs pls.
karlak
Just wanted to check what some optional extras mean....
four zone climate - I think is individual right and left heating for the rear passengers, perhaps with lower vents for the feet as well.
Detachable tow bar 13 pin (comfort) - Pretty obvious, but why the (comfort) description
ALSTON Ivory headlining - Is this a different material ? What would the material be on a Vogue SE as standard ? Any pics anywhere ? Seemed an expensive option
Deployable steps - Do these just come out and go away with the car door opening and closing ? can they be extended out all the time ? A car I have seen with these doesn't have mud flaps/guards, are there issues fitting mudguards with these steps due to them moving in and out ?
Post #602617 2nd Aug 2021 7:30pm
mjdronfield
You are right with the climate, mine just has a single knob for temperature in the rear, 4 zone has 2.
I don’t believe you can fit mud flaps with the deployable side steps. Could be wrong. Not sure why you’d want them out all the time if you had them. I read on here that the brackets break occasionally and it gets expensive to fix.
The trim and material is the same as a Vogue, bar semi aniline leather seats. It’s only the Autobiography and Supercharged that has leather everywhere.
Not sure what the Comfort bit on the tow bar is... though I think mine has that too....
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #602621 2nd Aug 2021 7:47pm
mjdronfield
Just had a look, seems there were 3 headlining options. Not sure what the difference of the non leather ones then.
Re the tow bar, looks like the detachable one is classed as Comfort, the other is the Farmers Hitch.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #602622 2nd Aug 2021 8:00pm
dhallworth
If you have deployable steps you really don't want them out all of the time. They hang quite low and would be susceptible to kerbs, etc. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
2007 Range Rover Supercharged in Java Black with Ivory Leather
Post #602631 2nd Aug 2021 11:11pm
As above really, if the steps were left out and your car was in access mode! You could easily snap them off on high kerbs!!! Shocked Thumbs Up
Post #602633 2nd Aug 2021 11:33pm
karlak
Thankyou for the replies.
The reason I asked about the side-steps was so you could have them out to help loading a roof rack, or washing the roof etc.
We are going to view the car at the weekend, so will check everything out the best we can. Thumbs Up
Post #602641 3rd Aug 2021 6:59am
Landphil
The side steps move in and out automatically when doors are opened or closed and on locking, unlocking.
There is a button in the car and a simple procedure that keeps the steps deployed for washing the roof.
Post #602642 3rd Aug 2021 7:07am
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
The same button also will keep them turned off?
Post #602643 3rd Aug 2021 8:00am
As above… Yes they can be locked in or out sir 👍
Post #602646 3rd Aug 2021 8:50am
karlak
Sorry to be a pain,, another check..
Rear Seat entertainment on a Vogue SE around 2011, I believe was standard spec.
What should the RSE come with,, I presume 2 headsets.. But, I have also seen photos of some sort of screen/controller. that sits in the rear arm rest ? What should be included with the RSE
Post #602745 3rd Aug 2021 9:36pm
dhallworth
RSE was optional on all models in 2011. It was only standard on the Vogue SE up to 2009 IIRC.
In the L322 with RSE you should have a DVD changer in the boot, 2 sets of infrared headphones and a remote control with the screen on it.
Post #602746 3rd Aug 2021 9:42pm
mjdronfield
All the specs for the 2011 cars are in the Wiki mate. I loaded a PDF up a month or so ago....
RSE was a £2500 option....
https://www.fullfatrr.com/forum/topic59697.html
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #602748 3rd Aug 2021 9:46pm
karlak
Yes, spotted that thanks,, very helpful..
it is just a car we have seen has rear screens but are not showing on a spec sheet we were provided. I guess they could be aftermarket.. Only have a poor picture grab at the moment. Will know more when we go and view at the weekend,, just wanted to be armed with the correct info .. Thumbs Up
Post #602749 3rd Aug 2021 9:54pm
dhallworth
They look original rear screens. After market ones usually have a different design.
Don’t get too hung up one RSE, it’s a very dated system and the picture quality isn’t all that. You’d be far better off with a couple of iPads in a holder if it’s something you want to get use out of.
Post #602750 3rd Aug 2021 9:58pm
mjdronfield
Yes, that looks factory fit. Should have 6 DVD changer in the boot and rechargeable remote in the rear armrest... and 2 headphones....
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #602752 3rd Aug 2021 10:37pm
