![]() | Home > Technical (L322) > 2011 Range Rover tdv8. Glovebox |
Sorry Dave but its a case of replacing the switchpack... Done loads! |
daveturbo Member Since: 11 Nov 2012 Location: county durham Posts: 107 ![]() ![]() ![]() |
How do i open the glovebox ,to replace the switch pack please ,buddy. Mercedes AMG w207
Buy a new switch, then you can see where the tangs are that hold the switch in… Remove the damaged switch using a trim tool, then hook up the new switch and voila! Glovebox’s will open 👍 |
Fitted a new Glovebox Switch assy ,and still not working. Mercedes AMG w207
With ign switched on or? |
I have tried with Ign on and off. Mercedes AMG w207
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1214 ![]() ![]() ![]() |
Might sound daft, but as I am assuming it is an electrical switch, have you checked the fuse for that system? |
The Fusebox is in the Glovebox lol Mercedes AMG w207
Spud Member Since: 12 Jul 2019 Location: Asif by Magic Posts: 130 ![]() ![]() ![]() |
Glovebox fuse is a 5 amp one in the luggage compartment i believe. 2006 4.2 SC |
Great i will check tomorrow. Mercedes AMG w207
Checked the Glovebox relay its fine, new switch pack fitted, still nothing, any more ideas Mercedes AMG w207
