Home > Technical (L322) > 4.2 V8 SC & LPG Non start no coms with ecu |
Spud Member Since: 12 Jul 2019 Location: Asif by Magic Posts: 130 |
Engine ecu powers with ign on, so 12v are Pins B4, B6, B17, B30 and B54.
21st Jul 2021 6:44pm |
Stormin12 Member Since: 21 Jul 2021 Location: Lancs Posts: 8 |
Thanks Spud,
21st Jul 2021 7:26pm |
Main relay R1 is in the E box under the bonnet.
21st Jul 2021 7:35pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3068 |
If you can start it by jumping the pins of the relay, have you tried replacing the relay?
22nd Jul 2021 12:55pm |
I can get the engine to turn over / crank by jumping the relay but it doesn't start. |
22nd Jul 2021 2:41pm |
It won't start if you do it that way I wouldn't think as the rest of the car doesn't see it turning over. The immobiliser will still be on as well I'd have thought.
22nd Jul 2021 3:01pm |
B1,2 3 & 5 earths are OK. When I switch the ignition on battery voltage drops from 12.6 to about 10.5 which won't be helping matters. Testing B6 gets full battery voltage 10.6. Only measuring about 1 volt on B4 and nothing on the other smaller pins B17,B30 & 54. I don't have a relay in the R1 position. Think it's the R10 relay that powers up the ECU. |
22nd Jul 2021 7:28pm |
Looks like you've lost ign supply at terminal 15 ( power to B17 ). I could understand no power to B30 from terminal 15 as it's fused. But B17 is supposed to be direct, so i would start from there.
22nd Jul 2021 8:15pm |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 |
if the brake lights do not work and you need to press the break pedal to get it started is it worth checking these first?
23rd Jul 2021 7:00am |
No need to apply brakes to start on 2006 model. Only need to apply brakes shift out of park.
23rd Jul 2021 10:52am |
Take it fuse 31p is in passenger compartment behind glove box? Link 5P? In same vicinity I guess. The manual download makes reference to ECM relay faults but which is the ECM relay. I only have four in the E box under bonnet. R3, R7 and R10 plus a micro for horn. R7 is to starter, I assumed R10 was ECU but maybe main power. Jumping this made no difference. Is the ECM replay referred to in manual on the fuse board behind glove box & which number is it? Had a nightmare with topix. Purchased a week subscription for £36 to be be able to view manuals and wiring diagrams and it's not granting me access. Multiple e-mails back and forth to JLR and getting nowhere. I don't have an R4 under the bonnet in the E box. |
23rd Jul 2021 6:03pm |
23rd Jul 2021 6:16pm |
In the E box you should have a bank of five normal size blade fuses.
23rd Jul 2021 7:04pm |
That seems to be showing an early version of the E fuse box.
23rd Jul 2021 11:28pm |
