Home > Technical (L322) > 4.2 V8 SC & LPG Non start no coms with ecu
Stormin12
United Kingdom 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
This has got me baffled.
Had an issue last week were car wouldn't start when I was collecting my daughter. Eventually got it going and on returning home found the battery earth terminal to be a little loose. Tightened it up and all good again or so I thought.
The folllowing day whilst on a trip out with the horse box on the car cut out suddenly on a trunk road junction roundabout and wouldn't restart. Being in a predicament had to call the AA.
I had tried calling up fault codes with my foxwell reader but saying couldn't read vin from dash so no go.
AA man turned up and found battery voltage low. Put it on boost and no joy. It did eventually start a couple of times an then cut out after a few minutes and ended up being recovered to home as it was a Sunday.
I' was convinced it was an ignition switch issue as all lights come on dash but no cranking. I also had a similar cut out and dead issue with a previous tdV8.
So I've replaced the ignition switch but no joy. Changed battery over to a known good one from another vehicle.
I can get the engine to crank by removing the relay in fuse box and jumping contacts, engine spins over OK so not a starter or battery fault.
Battery voltage reading is 12.6 volts with my multi-meter.
I can access all modules on diagnostic reader except the engine ECU PCM module.
All lights are on the dash just no cranking and start, regardless of whether in gas or petrol mode.
One strange one is that all lights work except brake lights. Live data from ECU doesn't recognize the brake switch as active even when pressed.
I've checked all fuses under bonnet and behind glove box and all OK.
I've checked all earths in the ecu fuse box area under bonnet and all seem OK, test same as full voltage from battery.
One issue I did have previously was two rear ABS sensors inoperative after changing lower arms. The new britpart ones didn't seem to be liked by the car and hadn't got round to getting genuine ones.
Anyone got any thoughts on further likely issues?
Post #601419 21st Jul 2021 6:19pm
Spud
England 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Engine ecu powers with ign on, so 12v are Pins B4, B6, B17, B30 and B54.
Grounds are B1, B2, B3, B5.
I see two more relay controlled powers in A95 and B50.
Bank B is the smaller connector on the engine ecu. 2006 4.2 SC
Post #601422 21st Jul 2021 6:44pm
Stormin12
Thanks Spud,
I'll do a bit more testing tomorrow with the meter when the rain has stopped.
Any idea where those relays are?
I've registered for topix but haven't got into it to have a look so far.
Post #601426 21st Jul 2021 7:26pm
Spud
Main relay R1 is in the E box under the bonnet.
The other two are fed via the main relay and would not contribute to an ecu no comms scenario. 2006 4.2 SC
Post #601427 21st Jul 2021 7:35pm
dhallworth
If you can start it by jumping the pins of the relay, have you tried replacing the relay?
Sorry if I'm stating the obvious but it's worth checking the simple things first Smile
2007 Range Rover Supercharged in Java Black with Ivory Leather
Post #601471 22nd Jul 2021 12:55pm
Stormin12
I can get the engine to turn over / crank by jumping the relay but it doesn't start.
Post #601484 22nd Jul 2021 2:41pm
dhallworth
It won't start if you do it that way I wouldn't think as the rest of the car doesn't see it turning over. The immobiliser will still be on as well I'd have thought.
See if there's a relay that's the same and swap them temporarily. It could be something as simple as a burnt relay that's not closing when it should do. It'll likely do nothing but it's a free and very simple thing to check Smile
When you energise the starter with the key, there will be 12v going to that relay which will pull the contacts shut. When using the paper clip you are effectively pulling the contacts shut which is why the engine turns. You could check between the other pins on the relay to see if you're getting 12v.
Post #601489 22nd Jul 2021 3:01pm
Stormin12
B1,2 3 & 5 earths are OK.
When I switch the ignition on battery voltage drops from 12.6 to about 10.5 which won't be helping matters.
Testing B6 gets full battery voltage 10.6. Only measuring about 1 volt on B4 and nothing on the other smaller pins B17,B30 & 54.
I don't have a relay in the R1 position. Think it's the R10 relay that powers up the ECU.
Post #601523 22nd Jul 2021 7:28pm
Spud
Looks like you've lost ign supply at terminal 15 ( power to B17 ). I could understand no power to B30 from terminal 15 as it's fused. But B17 is supposed to be direct, so i would start from there.
Maybe the diagram helps.
 2006 4.2 SC
Post #601527 22nd Jul 2021 8:15pm
Jayk69
United Kingdom 2012 Range Rover Vogue 4.4 V8 Barolo Black
if the brake lights do not work and you need to press the break pedal to get it started is it worth checking these first?
if you dont have your foot on the break it will not run.
just a thought 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #601560 23rd Jul 2021 7:00am
Stormin12
No need to apply brakes to start on 2006 model. Only need to apply brakes shift out of park.
I'll admit I had to double check in the manual that I wasn't fooling myself. I'm usually in the habit of holding the brakes on whilst starting anyway ready to shift into gear.
Post #601578 23rd Jul 2021 10:52am
Stormin12
Take it fuse 31p is in passenger compartment behind glove box?
Link 5P? In same vicinity I guess.
The manual download makes reference to ECM relay faults but which is the ECM relay. I only have four in the E box under bonnet. R3, R7 and R10 plus a micro for horn. R7 is to starter, I assumed R10 was ECU but maybe main power. Jumping this made no difference.
Is the ECM replay referred to in manual on the fuse board behind glove box & which number is it?
Had a nightmare with topix. Purchased a week subscription for £36 to be be able to view manuals and wiring diagrams and it's not granting me access. Multiple e-mails back and forth to JLR and getting nowhere.
I don't have an R4 under the bonnet in the E box.
Post #601625 23rd Jul 2021 6:03pm
Stormin12
Jumping R3 just triggers the pump in ABS unit.
R7 is direct to starter motor.
Post #601628 23rd Jul 2021 6:16pm
Spud
In the E box you should have a bank of five normal size blade fuses.
F1
(30A) Engine control module(ECM) (Diesel)
F2
(30A) Variable valve lift control module (petrol)
F3
(30A) Heated oxygen sensors (HO2S) (petrol)
F4
(30A) Engine control module(ECM) (petrol)
F5
(30A) Ignition system (petrol)
 2006 4.2 SC
Post #601641 23rd Jul 2021 7:04pm
Stormin12
That seems to be showing an early version of the E fuse box.
Mine is as per earlier attached image.
Post #601660 23rd Jul 2021 11:28pm
