![]() | Home > Technical (L322) > 4.2 V8 SC & LPG Non start no coms with ecu |
Spud Member Since: 12 Jul 2019 Location: Asif by Magic Posts: 130 ![]() ![]() ![]() |
Engine ecu powers with ign on, so 12v are Pins B4, B6, B17, B30 and B54.
Stormin12 Member Since: 21 Jul 2021 Location: Lancs Posts: 8 ![]() ![]() ![]() |
Thanks Spud,
Main relay R1 is in the E box under the bonnet.
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3146 ![]() ![]() ![]() |
If you can start it by jumping the pins of the relay, have you tried replacing the relay?
I can get the engine to turn over / crank by jumping the relay but it doesn't start. |
It won't start if you do it that way I wouldn't think as the rest of the car doesn't see it turning over. The immobiliser will still be on as well I'd have thought.
B1,2 3 & 5 earths are OK. When I switch the ignition on battery voltage drops from 12.6 to about 10.5 which won't be helping matters. Testing B6 gets full battery voltage 10.6. Only measuring about 1 volt on B4 and nothing on the other smaller pins B17,B30 & 54. I don't have a relay in the R1 position. Think it's the R10 relay that powers up the ECU. |
Looks like you've lost ign supply at terminal 15 ( power to B17 ). I could understand no power to B30 from terminal 15 as it's fused. But B17 is supposed to be direct, so i would start from there.
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 ![]() ![]() ![]() |
if the brake lights do not work and you need to press the break pedal to get it started is it worth checking these first?
No need to apply brakes to start on 2006 model. Only need to apply brakes shift out of park.
Take it fuse 31p is in passenger compartment behind glove box? Link 5P? In same vicinity I guess. The manual download makes reference to ECM relay faults but which is the ECM relay. I only have four in the E box under bonnet. R3, R7 and R10 plus a micro for horn. R7 is to starter, I assumed R10 was ECU but maybe main power. Jumping this made no difference. Is the ECM replay referred to in manual on the fuse board behind glove box & which number is it? Had a nightmare with topix. Purchased a week subscription for £36 to be be able to view manuals and wiring diagrams and it's not granting me access. Multiple e-mails back and forth to JLR and getting nowhere. I don't have an R4 under the bonnet in the E box. |
In the E box you should have a bank of five normal size blade fuses.
That seems to be showing an early version of the E fuse box.
