Home > In Car Electronics (L322) > Av input help
Jimes256
United Kingdom 2002 Range Rover Vogue 4.4 V8 Zermatt Silver
Av input help
Hi. So I had the converter lead already on the tv unit in boot. Tried connecting laptop up via an hdmi converter that is known good via projector. I get sound but no video. If I pull the video plug it gets a poor signal as you connect back up but I wonder what the problem can be. Set it to pal and ntsc but neither work. Anyone had anything similar? Cheers
Post #601511 22nd Jul 2021 7:26pm
Weegie
Just to check, have you tried AUX instead of CD? John
GAP iiD BT-Sold
Post #601514 22nd Jul 2021 7:46pm
Jimes256
Hi weegie. Not sure what you mean? I was in tv with av channel and nothing to do with cd.....
Post #601518 22nd Jul 2021 8:04pm
Weegie
I'm not entiry sure of your system but with NavTool, which I have fitted, to get audio I have to press the Audio button (the hard button beside the screen) and select AUX.
I wondered if yours had similar? John
GAP iiD BT-Sold
Post #601520 22nd Jul 2021 8:11pm
Jimes256
I’m pretty sure the av channel on tv mutes until video signal is received. I guess I need to try something like a DVD player with av out as the input to prove it’s not the converted hdmi signal causing the problem
Post #601524 22nd Jul 2021 8:30pm
