![]() | Home > Maintenance & Mods (L405) > Aircon |
Garyfax Member Since: 02 Feb 2015 Location: Halifax Posts: 124 ![]() ![]() ![]() |
Hi Folks.
Thanks Chalky. Yes I am waiting for a call off the garage to get it back in. They replaced an o ring seal last time which they thought was the problem. Hopefully they won’t charge again ! |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1231 ![]() ![]() ![]() |
Therein lies one of your problems, quote 'they thought it was the problem' Obviously I am guessing here but, sounds like they did not do a proper vacuum test prior to re-gassing. You obviously still appear to have a leak somewhere, they should fix it for free this time - Properly. |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16334 ![]() ![]() ![]() |
The above all sounds fine BUT, you have driven it for the last 8 weeks, and what's to say there isn't now a hole in the condenser? Unfortunately, the gas in these bloody things is sooooooo fine it escapes from any and everywhere! |
It’s going in later in the week for a check. The garage have already said it’s probably now leaking from somewhere different but we will see. Thanks for the replies . Incidentally has anyone any ideas why one side of the car appears cooler than the other ? |
Sarchopperman Member Since: 11 Aug 2017 Location: Aberdeenshire Posts: 33 ![]() ![]() ![]() |
See this link: https://www.hella.com/techworld/uk/Technic...tion-1831/
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8749 ![]() ![]() ![]() |
As Craig says it could be a different leak. I had a similar issue on my D4, took it to a national who couldn’t pull a vacuum so just gave it back… sorry mate that’s got a leak - can’t recharge it.
Zebedee Member Since: 09 Jun 2016 Location: Cheshire/South Manchester Posts: 395 ![]() ![]() ![]() |
My money is on a tiny hole in the condenser.
- 2017 L405 3.0 V6 Autobiography Sold: - 2013 L405 4.4 TDV8 Vogue - 2004 L322 4.4 Vogue (BRC LPG) - 2002 L322 4.4 HSE (having fixed timing chain guides) - 2000 P38 4.6 Vogue (BRC LPG) - 1981 2-door In-Vogue - 1980 Ex-Army SIII LWB - 1976 SIII LWB - 1968 SIIA Stripped for parts: - 2003 L322 4.4 Vogue |
Thanks for all your replies.
