Home > Maintenance & Mods (L405) > Aircon |
Garyfax Member Since: 02 Feb 2015 Location: Halifax Posts: 118 |
Hi Folks.
19th Jul 2021 2:37pm |
Thanks Chalky. Yes I am waiting for a call off the garage to get it back in. They replaced an o ring seal last time which they thought was the problem. Hopefully they won’t charge again ! |
19th Jul 2021 4:51pm |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1181 |
Therein lies one of your problems, quote 'they thought it was the problem' Obviously I am guessing here but, sounds like they did not do a proper vacuum test prior to re-gassing. You obviously still appear to have a leak somewhere, they should fix it for free this time - Properly. |
19th Jul 2021 5:37pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16281 |
The above all sounds fine BUT, you have driven it for the last 8 weeks, and what's to say there isn't now a hole in the condenser? Unfortunately, the gas in these bloody things is sooooooo fine it escapes from any and everywhere! |
19th Jul 2021 10:59pm |
It’s going in later in the week for a check. The garage have already said it’s probably now leaking from somewhere different but we will see. Thanks for the replies . Incidentally has anyone any ideas why one side of the car appears cooler than the other ? |
20th Jul 2021 4:31am |
Sarchopperman Member Since: 11 Aug 2017 Location: Aberdeenshire Posts: 33 |
See this link: https://www.hella.com/techworld/uk/Technic...tion-1831/
20th Jul 2021 9:58am |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8504 |
As Craig says it could be a different leak. I had a similar issue on my D4, took it to a national who couldn’t pull a vacuum so just gave it back… sorry mate that’s got a leak - can’t recharge it.
20th Jul 2021 11:58am |
Zebedee Member Since: 09 Jun 2016 Location: Cheshire/South Manchester Posts: 377 |
My money is on a tiny hole in the condenser.
20th Jul 2021 4:45pm |
Thanks for all your replies.
20th Jul 2021 5:47pm |
