Home > Maintenance & Mods (L405) > Aircon
Garyfax
England 2009 Range Rover Vogue SE TDV8 Santorini Black
Aircon
Hi Folks.
Air con not working on 2016 model just 2 months after getting it fixed under warranty . Passenger side appears to be slightly cooler than the drivers side but still not cold, Any ideas why this would be before I speak to the garage ? Regards
Post #601123 19th Jul 2021 3:37pm
Chalky
The people who should have fixed it didn't?
Put the setting on "Lo" and see how cold it gets. It should be ice cold, if it isn't then take it back as it's only 2 months ago you had it looked at. All LR cars from 1984
2021.5 Vogue SE D300 Carpathian Grey
2018 Vogue SE British Racing Green GONE
Post #601138 19th Jul 2021 4:50pm
Garyfax
Thanks Chalky. Yes I am waiting for a call off the garage to get it back in. They replaced an o ring seal last time which they thought was the problem. Hopefully they won’t charge again !
Post #601154 19th Jul 2021 5:51pm
Merchy
Therein lies one of your problems, quote 'they thought it was the problem' Obviously I am guessing here but, sounds like they did not do a proper vacuum test prior to re-gassing. You obviously still appear to have a leak somewhere, they should fix it for free this time - Properly.
Post #601163 19th Jul 2021 6:37pm
The above all sounds fine BUT, you have driven it for the last 8 weeks, and what's to say there isn't now a hole in the condenser? Unfortunately, the gas in these bloody things is sooooooo fine it escapes from any and everywhere! Banging Head Banging Head Banging Head
Post #601200 19th Jul 2021 11:59pm
Garyfax
It’s going in later in the week for a check. The garage have already said it’s probably now leaking from somewhere different but we will see. Thanks for the replies . Incidentally has anyone any ideas why one side of the car appears cooler than the other ?
Post #601203 20th Jul 2021 5:31am
Sarchopperman
United Kingdom 2011 Range Rover Vogue TDV8 Epsom Green
See this link: https://www.hella.com/techworld/uk/Technic...tion-1831/
Just pulling and holding a vacuum might show up a leak. The better way is to pressure test the system with forming gas (a mixture of Nitrogen and Hydrogen) and use a detector. This will pinpoint the leak allowing rectification. I think a vacuum check and guessing where the leak might be is half a job. Aircon gas be it R134a or R1234 is expensive and is harmful to the environment.
I would take it somewhere that will do a proper job RR L322 TDV8 4.4 SE 2019 to present
RR L322 TDV8 4.4 - 2016 to present
Discovery 2 TD5 - 2010 to 2016
Discovery 1 - 2000 to 2010
Post #601225 20th Jul 2021 10:58am
As Craig says it could be a different leak. I had a similar issue on my D4, took it to a national who couldn’t pull a vacuum so just gave it back… sorry mate that’s got a leak - can’t recharge it.
Took it to a local guy in Burton who put a pressure test and dye in it and found the hole in the condenser. Been fine now for 7 years
First off, has it lost the gas? If so then it’s leaking, if not then there is another issue. There is nothing that can't be fixed with a hammer😜😜
Post #601249 20th Jul 2021 12:58pm
Zebedee
United Kingdom 2013 Range Rover Vogue SDV8 Santorini Black
My money is on a tiny hole in the condenser.
Mine had a hole so small that nothing came up on vacuum test. It only started to leak when the system got hot and was found by tiny bubbling on the front of the condenser once it had been re-charged.
New condenser and re-gas was £225, but I had to fit the condenser - which wasn't overly complicated but does involve taking front bumper, plastic parts and slam panel off. Vent temperature when working correctly should get to ~4 degrees.
 Current:
- 2017 L405 3.0 V6 Autobiography
Sold:
- 2013 L405 4.4 TDV8 Vogue
- 2004 L322 4.4 Vogue (BRC LPG)
- 2002 L322 4.4 HSE (having fixed timing chain guides)
- 2000 P38 4.6 Vogue (BRC LPG)
- 1981 2-door In-Vogue
- 1980 Ex-Army SIII LWB
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
- 2003 L322 4.4 Vogue
Post #601278 20th Jul 2021 5:45pm
Garyfax
Thanks for all your replies.
Incidentally it was tested with the dye and a small leak was found on the o ring which was replaced.
Bit of a strange one, when I got in the car this morning it was blowing cold but again passenger side only, this lasted about an hour into the drive and then both sides were warm again. Seems strange, my feeling is that if the gas was low I would get no cold air which suggests something else ? Any ideas ?
I will post results of the check when I take it back in on Thursday.
Post #601293 20th Jul 2021 6:47pm
