![]() | Home > Maintenance & Mods (L322) > What to do if your DPF is blocked... |
SinbadRose Member Since: 21 Aug 2017 Location: Merseyside Posts: 114 ![]() ![]() ![]() |
Thanks for that, will try a longer run tonight, fingers crossed it sorts it. |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4332 ![]() ![]() ![]() |
I think you may have an issue as it came on after a run back from Cornwall and has not gone out after 2 runs. Careful as you may run into a red. Grab an iid and you can look at soot levels, egt temps, dpf pressure voltage etc. Without it, running blind.
wolv79 Member Since: 06 Nov 2019 Location: Burgas Posts: 4 ![]() ![]() ![]() |
Hello Guys,
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3821 ![]() ![]() ![]() |
Wolv79,
Hi Mike,
Wolve79,
My iid is now updated to 2765 thanks to Pats excellent service |
Mike
Rob,
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 335 ![]() ![]() |
Hi Dimitar, great write up and brilliant to hear you are sorted.
Many thanks for the explanation!
Dimitar/ Gents.
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
Great news!
