Home > Maintenance & Mods (L405) > Retracting side steps |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
Um no sir, the motors work on torque to stop the step if it feels like ss leg has gotten stuck... This means, when the motor gets worn it stops either deploying or retracting... |
12th Jul 2021 11:46pm |
CMJ Member Since: 10 Oct 2010 Location: Lancashire Posts: 208 |
So do I deduce from this Craig a new motor is likely to be the remedy. Thanks.
13th Jul 2021 5:58am |
horse86 Member Since: 09 Dec 2014 Location: PA Posts: 860 |
mine are acting up too.. driver side will come out a little and stop...without fully extending or retracting so it's stuck in a sort of in between. Some times come out a bit then go back in. Passanger side is doing this too now....comes out, then goes back. Frustrating as hell. Great mod.....when they work. But they have been nothing but a PITA for a few months now.
13th Jul 2021 2:35pm |
Andy S Member Since: 16 Jun 2013 Location: Sevenoaks Posts: 1018 |
Fixed steps are the way to go…… |
13th Jul 2021 2:39pm |
I had fixed and removed them for deployable lol 2014 FF Autobiography 5.0 SC
13th Jul 2021 2:49pm |
Lyonhead Member Since: 05 Aug 2017 Location: Cardiff Posts: 349 |
I believe that if they sense a restriction of any sort they stop deploying or retracting. So initial inspection for any mud/rocks etc and then liberally lubricate and check freedom of movement of linkages.
13th Jul 2021 2:50pm |
did find that my drivers side worked for a few days after taking it through a car wash. Might try crawling under with a power washer and then try lubing again as a final try.
13th Jul 2021 2:54pm |
Martin2 Member Since: 15 Jun 2020 Location: Northamptonshire Posts: 766 |
Only when you're sat in the car and don't have to look at them..... MY23 Panamera E-Hybrid MY19 SDV8 Autobiography - Sold |
13th Jul 2021 4:30pm |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3779 |
I lubed mine and they started working perfectly and still are (I wish I hadn't just said that). They were playing up. Geoff |
13th Jul 2021 4:54pm |
I sprayed some white lithium grease where I thought they were pivoting (pins go through the bracket).....but didnt seem to make much of a difference. 2014 FF Autobiography 5.0 SC
13th Jul 2021 6:35pm |
jettec Member Since: 16 Jul 2013 Location: Melbourne Posts: 229 |
Try lubricating with garage door silicone spray won't attract dirt and will get right into the linkages. |
13th Jul 2021 11:42pm |
Get this at Home Depot etc? Do you have a brand you’d suggest? 2014 FF Autobiography 5.0 SC 2008 FFRR (sold) 2008 BMW M5 |
14th Jul 2021 12:42am |
Sorry the brands we have Australia would not be in the USA .
14th Jul 2021 6:37am |
I just used what I had, it was actually the stuff I use on my bike chain - just thin oil spray but I did douse everything. Geoff |
14th Jul 2021 6:41am |
