Home > Maintenance & Mods (L405) > Retracting side steps
CMJ
2015 Range Rover Autobiography TDV6 Santorini Black
Hi all, whilst on holiday my drivers side step has started to misbehave. I have had a couple of issues before this with my passenger step but all fixed with some lubrication and has been working as good as gold ever since.
The drivers step extracts but only retracts to approx 50%. It appears to be working as it should other than it is not fully retracting.
The step also seems to try to rest itself if I drive at low speed as it it knows it is not fully retracted.
Have tried to solve with disconnecting the battery and have added some lubrication but it’s the motor that appears to be locking.
Is there any sort of any jam that needs to be reset ? 2013 L405 AB 4.4SDV8 Luxor/Ivory, 2007 Vogue TDV8 Epson Green/Sand, 2008 Vogue TDV8 Buckingham Blue/Sand, 2003 Vogue 4.4 LPG Epsom Green/Sage, 1998 Vogue SE 4.6 LPG Epsom Green/Cream
Post #600420 12th Jul 2021 8:53pm
Um no sir, the motors work on torque to stop the step if it feels like ss leg has gotten stuck... This means, when the motor gets worn it stops either deploying or retracting...
Post #600433 13th Jul 2021 12:46am
CMJ
So do I deduce from this Craig a new motor is likely to be the remedy. Thanks.
Assume there is no test/reset in the software? Strange thing is it just started out of the blue and is actually working , although only retracting to 50%. 2013 L405 AB 4.4SDV8 Luxor/Ivory, 2007 Vogue TDV8 Epson Green/Sand, 2008 Vogue TDV8 Buckingham Blue/Sand, 2003 Vogue 4.4 LPG Epsom Green/Sage, 1998 Vogue SE 4.6 LPG Epsom Green/Cream
Post #600437 13th Jul 2021 6:58am
horse86
United States 2014 Range Rover Autobiography 5.0 SC V8 Causeway Grey
mine are acting up too.. driver side will come out a little and stop...without fully extending or retracting so it's stuck in a sort of in between. Some times come out a bit then go back in. Passanger side is doing this too now....comes out, then goes back. Frustrating as hell. Great mod.....when they work. But they have been nothing but a PITA for a few months now.
I've found if I "help it" by pulling or pushing when I open ot close the door it will come down and/or retract but obviously this shouldnt be needed. 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #600512 13th Jul 2021 3:35pm
Andy S
United Kingdom 2015 Range Rover Vogue SE SDV8 Aintree Green
Fixed steps are the way to go……
Post #600515 13th Jul 2021 3:39pm
horse86
I had fixed and removed them for deployable lol 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #600517 13th Jul 2021 3:49pm
Lyonhead
Wales 2019 Range Rover SVAutobiography 5.0 SC V8 Loire Blue
I believe that if they sense a restriction of any sort they stop deploying or retracting. So initial inspection for any mud/rocks etc and then liberally lubricate and check freedom of movement of linkages.
If still under warranty, dont put it off, get the car straight into the a Dealership. Thumbs Up Thumbs Up
Hopefully CMJ and Horse86 you both get them sorted and working properly again Wink 19MY SVA-Dynamic Spectral Chromoflair Blue but colour not available in profile
2016 RRS SVR Estoril Blue - Gone
2010 RRS 5.0 Supercharged Navara Bronze - Gone
2008 RRS 4.2 Supercharged Black - Gone
2006 RRS 2.7 Diesel Rimini Red- Gone
Post #600519 13th Jul 2021 3:50pm
horse86
did find that my drivers side worked for a few days after taking it through a car wash. Might try crawling under with a power washer and then try lubing again as a final try.
I also noticed I can hear a "click"....almost sounds like a pebble hitting the step when the driver side retracts/deploys. Not sure what that is.
Anyone know where the sensor is on these that detects an obstacle? Maybe I need to clean that? 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #600520 13th Jul 2021 3:54pm
Martin2
Only when you're sat in the car and don't have to look at them..... Very Happy MY23 Panamera E-Hybrid
MY19 SDV8 Autobiography - Sold
Post #600532 13th Jul 2021 5:30pm
supershuttle
I lubed mine and they started working perfectly and still are (I wish I hadn't just said that). They were playing up. Geoff
Post #600535 13th Jul 2021 5:54pm
horse86
I sprayed some white lithium grease where I thought they were pivoting (pins go through the bracket).....but didnt seem to make much of a difference. 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #600548 13th Jul 2021 7:35pm
jettec
Australia 2013 Range Rover Autobiography TDV8 Fuji White
Try lubricating with garage door silicone spray won't attract dirt and will get right into the linkages.
Post #600572 14th Jul 2021 12:42am
horse86
Get this at Home Depot etc? Do you have a brand you’d suggest? 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #600576 14th Jul 2021 1:42am
jettec
Sorry the brands we have Australia would not be in the USA .
You should fit this spray at any hardware shop. Home Depo. etc.
Post #600580 14th Jul 2021 7:37am
supershuttle
I just used what I had, it was actually the stuff I use on my bike chain - just thin oil spray but I did douse everything. Geoff
Post #600581 14th Jul 2021 7:41am
