Home > Technical (L322) > Steering rack prices (rip off) |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8195 |
You can get it even cheaper if you have the time...
7th Jul 2021 11:17pm |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1206 |
I had one fitted under warranty and the final bill was £3400!!!! |
8th Jul 2021 12:06am |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1182 |
Haylands answer is the one to follow, unless you have a specialist refurbishment company near you.
8th Jul 2021 1:09am |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2643 |
Had a similar issue when I bought a new to me 2010 322. New prices were mental, as I’d only had it 2 weeks, it was being covered by the ropey 2nd hand car dealer warranty which wouldn’t stretch to the huge expense main dealers wanted. I ended up with a remanufactured rack which iirc was around £700 ish plus fitting, which took it to just over a grand all in . Getting a remanufacture is money well saved as long as you have alternative means of transport. Think they are ZF units . |
8th Jul 2021 6:38am |
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 |
Price is on par with other similar brands…. It’s not a corsa or escort. 2-3k for a rack is no surprise to me. This is a large luxury car, servicing and maintenance costs are similar to BMW, Mercedes etc. |
8th Jul 2021 8:51am |
Barmybrummie Member Since: 03 Apr 2021 Location: Somewhere in the valleys Posts: 654 |
Due to work commitments, no space at home or the inclination in overhauling it myself, refurbished is the way to go.
8th Jul 2021 4:00pm |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 768 |
Lion Automotive come highly recommended on the Disco forum for reconditioned steering racks.
8th Jul 2021 9:39pm |
Thanks KN I've just sent them an email. See what they can do for me. Would I be right in thinking that new racks need to be programmed to the car? |
9th Jul 2021 8:15am |
I don't believe so. I think it's just a case of removing the old one and refitting the new one.
9th Jul 2021 8:45am |
Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 689 |
No a replacement rack doesn't need any programming. Fit, fill with fluid, bleed & test & then forget / use as normal. I was really lucky & got a good second hand rack via local RR breaker for £90 & was able to fit it myself. Paul, 2001 Discovery 2 TD5, 211,000 miles & climbing 2006 FFRR TDV8 Vogue 145,000 miles & climbing Member of Midland (Land) Rover Owners Club, www.mroc.co.uk |
9th Jul 2021 9:56pm |
