Home > Maintenance & Mods (L322) > Second Battery Install Help |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7825 |
The sockets are permanently live, until the 2010 facelift, then they are not.....ask me how I know 🤣 ask me if I spent best part of £300 on a cool box I can’t really use. 🤣
3rd Jul 2021 6:10pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3979 |
As above none of the fuses are ignition controlled but running above the fuse board is a thin green wire which is ignition controlled. Depending on what you want to achieve this wire can be used to trigger a relay, the output of which is then ignition controlled. |
3rd Jul 2021 6:22pm |
batfink Member Since: 20 Jun 2011 Location: Milton Keynes Posts: 190 |
I should have said that I’m after an ignition controlled fuse so that I can plug in to a relay, so that the battery isolated when the car isn’t in use.
3rd Jul 2021 7:13pm |
I’ll take a look for that green wire tomorrow 👍 |
3rd Jul 2021 7:38pm |
The green wire is actually green / yellow ( ) and is in this harness, just find a convenient place to splice into it.
3rd Jul 2021 8:10pm |
oggy Member Since: 09 Sep 2020 Location: padstow cornwall Posts: 395 |
hi what fuse does the firm land rover upgrades suggest to use batfink new vehicle purchase
3rd Jul 2021 8:51pm |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 798 |
The simplest and in my opinion the best way to connect a 2nd battery in the rear is by using a cheap voltage sensing relay. Take the live from the big red cable going to the rear fusebox. I would also recommend lifting the loom out of the void to stop any chance of the battery rubbing through any wires. Simple and cheap
4th Jul 2021 6:33am |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2516 |
Yes - replace the appropriate relay in the passenger fuse panel with a link made with 2 spade terminals and appropriate size wire. |
4th Jul 2021 7:56am |
Hi Oggy, They said to use the fifth fuse along but that's for the rear blower, so they must have been using a latter RR and they haven't gotten back to me when I've emailed them. |
4th Jul 2021 9:24pm |
Their kit is pretty good and does link to the big red cable at the rear fusebox. It has a relay and the negative goes to the body (after clearing away the paint). I did move the loom off of the floor and moved it to the front of the battery so it won't rub. I also used my Dremmel and removed the captive screws the cable ties were on, which means the battery sits nicely on the floor and all the trim panels go back with no problem. Here's a picture of the kit (from someone elses youtube channel) |
4th Jul 2021 9:29pm |
The VSR in my link goes between the 2nd battery and the fuse box main feed red wire, similar to your pic. When the car is running the 2nd battery gets charged, when you turn off the engine the 2nd battery is isolated. Fully automatic, no chance of forgetting. The beauty of this is that the charging must be over 13.8v before the switch, not 12v or less with a standard relay. Don't forget a meaty resettable fuse, I can't see one in that pic. I have connected my rear 12v socket directly to the 2nd battery having removed it from the loom 2007 TDV8 VSE
4th Jul 2021 11:45pm |
So an update on this. I've had Luxury Land Rover Upgrades contact me and they've said that I can splice into the Green cable that goes into the towing connector (white block near the fuse panel on the rear). So I'm assuming that's the same Green cable that was mentioned before.
6th Jul 2021 7:57am |
hi batfink that is sounding a lot better yes i would say that is the one that niceday is talking about does this wire fire up the relay will that still be fused or not new vehicle purchase
6th Jul 2021 5:09pm |
Apparently there’s no need to add a fuse as he said it’s fused upstream from there already. |
6th Jul 2021 5:28pm |
