Home > Technical (L322) > Windscreen washer pump |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 |
I know you have said you have no noise, but mine packed up a few days ago. It was such a simple thing you may have alerady thought of it- the pipe to the washer jet comes out over the battery and was pinched by the bonnet when closed. I assume it's similar on the S/C to the TDV8.
8th Mar 2019 12:46pm |
Jpboost Member Since: 23 Jul 2018 Location: Gatwick Posts: 72 |
Cheers for the reply.
8th Mar 2019 1:07pm |
Blankone Member Since: 10 Aug 2016 Location: St Helens Posts: 21 |
Hi, have you managed to sort out this problem as I have the same issue on a 2009 S/C.
9th Mar 2019 5:09pm |
Hi,
10th Mar 2019 9:42pm |
bgennette Member Since: 13 Jan 2013 Location: Newcastle Posts: 74 |
From what I remember there are 3 identical pumps that push-in to rubber grommets near the bottom of the wash water tank.
30th Mar 2019 4:02am |
RR2B Member Since: 04 Aug 2020 Location: Rowlands Castle Posts: 251 |
Exact same problem manifested itself today. I'll have a look tomorrow, I'm sure it's a 5 minute fix 2011MY 4.4TDV8 Autobiography Baltic Blue TVR Griffith Alfa Romeo Mito QV |
3rd Jul 2021 7:01pm |
It's a while back now, but from memory mine needed a pump.
3rd Jul 2021 7:47pm |
Rear screen washer working, headlamp washers working, fuse 38 is fine. Assume it must be the washer motor. 2011MY 4.4TDV8 Autobiography Baltic Blue
4th Jul 2021 10:40am |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1180 |
Thought mine failed yesterday, turned out to be an empty washer bottle, perfect, but then thought, no low level warning goddamit so obviously need to check the sensor. Another job for the list. |
4th Jul 2021 11:18am |
So near yet so far - I can clearly see the washer pumps in my inspection mirror, but how to access? Remove wheel liner? But can this be done without jacking car up? Or can I leave everything in place and improvise some form of keyhole surgery to extract the offending pump? Life used to be so simple.... 2011MY 4.4TDV8 Autobiography Baltic Blue TVR Griffith Alfa Romeo Mito QV |
5th Jul 2021 7:56am |
The 3 washer motors are simply 'push fitted' into 3 grommets on a horizontal or vertical ledge near the bottom rear of the tank. [horizontal early models, vertical after facelift]
26th Aug 2021 6:15am |
SomersetRR Member Since: 31 Aug 2021 Location: Somerset Posts: 3 |
Hi all
31st Aug 2021 9:34am |
DaveK Member Since: 18 Oct 2013 Location: StHelens Posts: 790 |
Does any one know any common leak probelems ? Lost all the fluid out of my screen tank. Can see a steady drip. Put a camera up before and could see bottom of middle pump dripping. |
21st Nov 2021 5:18pm |
Wynno Member Since: 19 Apr 2022 Location: Aylesbury Posts: 14 |
Appreciate this is an old post, but did SomersetRR or anyone else ever find the location of the screenwash relays? I'm having the exact same issue - can see them on the wiring diagram, but can't find them?
1st Sep 2024 9:31am |
