Home > Technical (L322) > Windscreen washer pump
Jpboost
Hi All,
Windscreen washers have stopped working. No noises or anything.
Headlight washers still work and I've checked all fuses that appear relevant. I'm assuming the pump have have just died, but seems odd to be perfect one day and not the next.
Obviously it's a range rover, so there's always the chance that the system is far more complex that I could possibly have imagined...
Anyone got any pointers for things to check? A search hasn't shown up much, so presume it's not a common fault.
Car is 2010 5.0 S/C autobiography .
Cheers
Jon
Post #507951 8th Mar 2019 11:31am
rjff
I know you have said you have no noise, but mine packed up a few days ago. It was such a simple thing you may have alerady thought of it- the pipe to the washer jet comes out over the battery and was pinched by the bonnet when closed. I assume it's similar on the S/C to the TDV8.
Worth a look? Cheers
Richard
Gap IIDBT
Post #507964 8th Mar 2019 12:46pm
Jpboost
Cheers for the reply.
I don't think it can be that, as I also tested with the bonnet open, but always worth another check that the pipe isn't pinched elsewhere.
I'll see if I can borrow a spare pair of hands so I can check in the engine bay for the pump running while someone pulls the lever.
Post #507966 8th Mar 2019 1:07pm
Blankone
United Kingdom 2009 Range Rover Vogue 4.2 SC V8 Buckingham Blue
Hi, have you managed to sort out this problem as I have the same issue on a 2009 S/C.
Pull the stalk and wipers move but pump not working, I have checked all fuses which are all good also checked for power at the pump and there is none so presume an electrical fault somewhere?
It also seems to have affected the rear wash/wipe as that’s stopped working altogether so maybe connected to the fronts?
Anyone any idea if there are any relays to check or am I looking at an ECU issue, searched the net but can’t find much so any help would be greatly appreciated as it’s failed the MOT!
Post #508105 9th Mar 2019 5:09pm
Jpboost
Hi,
I'm afraid I've not fixed it yet.
I did a hard battery reset today but that didn't affect anything.
Not had a chance to get to the pump and see if it's actually getting power when the stalk is pulled.
Genuine pump is 45, pattern ones on eBay for a tenner or so.
Have you made any progress?
I'm going to see if I can find a wiring diagram to trace looking for relays and other fuses.
Cheers
Post #508238 10th Mar 2019 9:42pm
bgennette
Australia 2003 Range Rover HSE Td6 Java Black
From what I remember there are 3 identical pumps that push-in to rubber grommets near the bottom of the wash water tank.
Tank is held with just 2 screws along it top, plus 1 screw near the top of the filler neck. Pumps are (from filler neck side) rear, front, headlights.
Try swapping the headlight washer motor with the non-working windscreen washer motor (swap hose and electric plug). If that works then there is no real rush to source a reasonably priced replacement motor.
Oh, take a picture of one of the pumps (against a ruler) with the ID code showing, to help getting a new one.
bye. 2003 TD6, EGR delete, vortex crankcase breather update, performance chip, UHF 2 way, Android head unit, crash camera on dash, always-on rear view camera to mirror screen, LED DRL`s, Electric trailer brake controller. FSR replaced. Pulling 3T caravan all about Australia
Post #510281 30th Mar 2019 4:02am
RR2B
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Baltic Blue
Re: Windscreen washer pump
Jpboost wrote:
Hi All,
Cheers
Jon
Exact same problem manifested itself today. I'll have a look tomorrow, I'm sure it's a 5 minute fix Big Cry 2011MY 4.4TDV8 Autobiography Baltic Blue
TVR Griffith
Alfa Romeo Mito QV
Post #599563 3rd Jul 2021 7:01pm
Jpboost
It's a while back now, but from memory mine needed a pump.
I was a bit surprised it had just failed like that, but wasn't too bothered as it was warrantied at the time and the garage has swapped it out before they told me.
Post #599570 3rd Jul 2021 7:47pm
RR2B
Rear screen washer working, headlamp washers working, fuse 38 is fine. Assume it must be the washer motor. 2011MY 4.4TDV8 Autobiography Baltic Blue
TVR Griffith
Alfa Romeo Mito QV
Post #599611 4th Jul 2021 10:40am
Merchy
Thought mine failed yesterday, turned out to be an empty washer bottle, perfect, Thumbs Up but then thought, no low level warning goddamit Censored so obviously need to check the sensor. Another job for the list.
Post #599614 4th Jul 2021 11:18am
RR2B
So near yet so far - I can clearly see the washer pumps in my inspection mirror, but how to access? Remove wheel liner? But can this be done without jacking car up? Or can I leave everything in place and improvise some form of keyhole surgery to extract the offending pump? Life used to be so simple.... 2011MY 4.4TDV8 Autobiography Baltic Blue
TVR Griffith
Alfa Romeo Mito QV
Post #599670 5th Jul 2021 7:56am
bgennette
The 3 washer motors are simply 'push fitted' into 3 grommets on a horizontal or vertical ledge near the bottom rear of the tank. [horizontal early models, vertical after facelift]
Undo the power plug then use a large flat bladed screw driver to lever the suspect motor out. [The tank will empty all over your feet] Go here to see how -
Pull out the headlight pump too; swap over the hose and power plug then put the good motor back.
Find a suitable wood or plastic plug to temporarily replace the pump while you fix the gunged up pump or source a replacement.
Post #604812 26th Aug 2021 6:15am
SomersetRR
United Kingdom 2011 Range Rover Autobiography 5.0 SC V8 Fuji White
2010-12 Rear Washer Pump Relay
Hi all
Re-posting this here because i inadvertently posted it originally on the wrong topic section.
Following on from the discussion above, I am really struggling to find the relay for the rear washer motor on my 2011 L322 Autobiography (5.0L SC Petrol). The wiring diagram (which was really difficult to find for the 2010-12 version) shows the front and rear washer relays in the central control box which i understand to be the fuse box behind the glove box which only has 3 relays in it for the cigarette lighters and audio system. In the 2002-2009 versions of the L322 the relays were behind the battery but in the 2010-12 version there is nothing behind the battery and in front of the battery is the ECU. Does anyone have any ideas? I have seen a couple of threads on here about the same thing but the question was never answered as far as i can see. I am pretty sure it is the relay that is caput rather than the washer motor because when i push the stalk back no power goes to the washer motor but i tried switching the front washer plug onto the rear washer motor, pulled the stalk forward and the rear motor pumped fine out of the rear jet.
Pulling my hair out trying to locate the relay so any insight would be appreciated.
Thanks in advance!
Post #605240 31st Aug 2021 9:34am
DaveK
United Kingdom 2013 Range Rover Vogue TDV6 Corris Grey
Does any one know any common leak probelems ? Lost all the fluid out of my screen tank. Can see a steady drip. Put a camera up before and could see bottom of middle pump dripping.
Post #613326 21st Nov 2021 5:18pm
Wynno
Appreciate this is an old post, but did SomersetRR or anyone else ever find the location of the screenwash relays? I'm having the exact same issue - can see them on the wiring diagram, but can't find them?
Thanks, Ian
 Current - 2010 Range Rover 4.4TDV8 Vogue SE Auto
Current - 2014 Defender 90 XS 2.2
Previous - 2020 Evoque D180 R-Dynamic SE Black Auto
Previous - 2016 Discovery Sport Auto 2.0 TD4 HSE Black Auto
Previous - 2010 Freelander 2 2.2 Diesel Auto
Post #699226 1st Sep 2024 9:31am
