![]() | Home > Technical (L322) > Windscreen washer pump |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 ![]() ![]() ![]() |
I know you have said you have no noise, but mine packed up a few days ago. It was such a simple thing you may have alerady thought of it- the pipe to the washer jet comes out over the battery and was pinched by the bonnet when closed. I assume it's similar on the S/C to the TDV8.
Jpboost Member Since: 23 Jul 2018 Location: Gatwick Posts: 73 ![]() ![]() ![]() |
Cheers for the reply.
Blankone Member Since: 10 Aug 2016 Location: St Helens Posts: 21 ![]() ![]() ![]() |
Hi, have you managed to sort out this problem as I have the same issue on a 2009 S/C.
Hi,
bgennette Member Since: 13 Jan 2013 Location: Newcastle Posts: 88 ![]() ![]() ![]() |
From what I remember there are 3 identical pumps that push-in to rubber grommets near the bottom of the wash water tank.
RR2B Member Since: 04 Aug 2020 Location: Rowlands Castle Posts: 254 ![]() ![]() ![]() |
Exact same problem manifested itself today. I'll have a look tomorrow, I'm sure it's a 5 minute fix ![]() TVR Griffith Alfa Romeo Mito QV |
It's a while back now, but from memory mine needed a pump.
Rear screen washer working, headlamp washers working, fuse 38 is fine. Assume it must be the washer motor. 2011MY 4.4TDV8 Autobiography Baltic Blue
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1214 ![]() ![]() ![]() |
Thought mine failed yesterday, turned out to be an empty washer bottle, perfect, |
So near yet so far - I can clearly see the washer pumps in my inspection mirror, but how to access? Remove wheel liner? But can this be done without jacking car up? Or can I leave everything in place and improvise some form of keyhole surgery to extract the offending pump? Life used to be so simple.... 2011MY 4.4TDV8 Autobiography Baltic Blue TVR Griffith Alfa Romeo Mito QV |
The 3 washer motors are simply 'push fitted' into 3 grommets on a horizontal or vertical ledge near the bottom rear of the tank. [horizontal early models, vertical after facelift]
SomersetRR Member Since: 31 Aug 2021 Location: Somerset Posts: 3 ![]() ![]() ![]() |
Hi all
DaveK Member Since: 18 Oct 2013 Location: StHelens Posts: 791 ![]() ![]() ![]() |
Does any one know any common leak probelems ? Lost all the fluid out of my screen tank. Can see a steady drip. Put a camera up before and could see bottom of middle pump dripping. |
Wynno Member Since: 19 Apr 2022 Location: Aylesbury Posts: 14 ![]() ![]() ![]() |
Appreciate this is an old post, but did SomersetRR or anyone else ever find the location of the screenwash relays? I'm having the exact same issue - can see them on the wiring diagram, but can't find them?
