![]() | Home > Maintenance & Mods (L405) > Tyres wearing out on inside of tyres |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8530 ![]() ![]() ![]() |
These any good...?
jettec Member Since: 16 Jul 2013 Location: Melbourne Posts: 229 ![]() ![]() ![]() |
Thanks for posting that I will ask the tyre repair shop if they will work.
Rears are adjustable, there are cam bolts on the hub bushes, they are usually very tight and corroded in the UK...
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4332 ![]() ![]() ![]() |
You need to find a different tyre guy |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16334 ![]() ![]() ![]() |
Ditto ^ |
Hi could you supply drawing of these hub bushes, as the tyre shop showed me a drawing from the manual the shows Toe/Cam bolts on the lower control arm #5500c that adjusts toe movement on rears and a little bit of camber, but mainly for Toe of rear tyres
Sorry getting confused with myself (doesn't take much) that comment was for a L322 not a L405, not a clue what it has at the back... As has been said above, try somewhere else, if there is no adjustment then it's usually fixed within specifications unless you have damaged suspension components... Pete __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click for Project Fatty off roader- |
Update managed to get Adjustable upper control rods from supplier. The tyre wear has been an issue from new.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2643 ![]() ![]() |
The front upper control arms are available from LR in 3 different lengths but the Meyle adjustable version sounds a much better option. |
Yes I bought the meyle arms very nice. |
