![]() | Home > Technical (L322) > Rear shocks |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 754 ![]() ![]() |
Yes, It is that easy, just make sure you support the lower arm when you remove the bottom bolt, and it is easier if you depressurise the air bag first.
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 491 ![]() ![]() ![]() |
I have also read on here that it's extremely common on these vehicles to have that and if it's just a light misting then they shouldn't need changing it's just when it's more than a misting they are bad. Current 2007 TDV8 Vogue Buckingham Blue |
Found the post here https://www.fullfatrr.com/forum/topic31802...ear+shocks Current 2007 TDV8 Vogue Buckingham Blue |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 ![]() ![]() ![]() |
did mine recently that easy and i did not have to depressurize the air bag just had another trolley jack to lift into place. less than 30 mins job done on my drive. 2012 Vogue 4.4 TDV8 - Current
RRDunc Member Since: 26 Feb 2020 Location: Leicestershire/Warwickshire border Posts: 520 ![]() ![]() ![]() |
Think I'll leave them for a bit, then.
